Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 02-23-2012, 03:28 PM   #1
sly the dogman
Default Owners nightmare...
First spool up for setting on rate mode, I let it seetle on the ground light on its skids for about 1 minute or so, you know just in case, lift off nearly perfect only a slight drift to the left otherwise spot on. Hovering at shoulder hight, approx 3 minutes in flight heard a pop then it droped, the belt snaped AGAIN, (that's the reason of my last crash in early september). And no the belt wasen't fixed to tight, I could spin the head freely with barely any restance. It feel on a patch of ice, tail end first, tail grips, blades, landing gear brook off completely in pieces, one main blade split open 2 inches long, fly-bar, links to the main blade poped off, 1 link seperated in 2. This is what I see first hand. What pisses me off the most is that I don't have the funds to rebuild it 5.5 may have to go the standard 500 route, even then. I'll take a look later, I'm to pissed right now to give it a closer look. Did I tell you I was pissed, ya I think I did.
ID:	292663   Click image for larger version
ID:	292664   Click image for larger version
ID:	292665   Click image for larger version
ID:	292666   Click image for larger version
ID:	292668   Click image for larger version
ID:	292669   Click image for larger version
We do accept FB parts for Compass 5.5
sly the dogman is offline        Reply With Quote
Old 02-23-2012, 07:17 PM   #2
kelseh
It wasn't too loose and rubbing on the the tail rotor housing was it? Sorry for your loss. That really sucks. How many flights did you have on the new belt.
Blade 550x, Atom 500 FBL, Trex 450 Pro FBL, DX8
kelseh is offline        Reply With Quote
Old 02-23-2012, 07:59 PM   #3
sly the dogman
Absolutely no wear and tare on the belt and it was 31/2 to 4 minutes tops in its first flight ! I did spool it up on the floor a while back for tail directions purposes and just to hear the tail blades and the motor running, did not have any main blades (DA !). After that moment I did check the belt remembering what happen in september wanted to be sure it was in good condition and it was. Really don't know what happened, there are frindges on each end of the belt indicating a tear maybe or a snap, I'm not an expert. Next belt installation will be bouble and triple checked, for sure.
Qué sera, sera.
What can I say, I'm not pissed off anymore, there are more important things going on in my life than a crashed heli.
Old 02-23-2012, 08:16 PM   #4
TallPaul
Sylvan. I know it doesn't help, but I'm sorry.
Compass Chronos; Compass 6hvU; Compass Atom 500; FLIP-FPV ; most with iKON; Spektrum DX8
TallPaul is offline        Reply With Quote
Old 02-23-2012, 08:28 PM   #5
buzzsaw 46
Any chance your one of pulleys have a deformity that could be causing the breaks?
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX.
buzzsaw 46 is offline        Reply With Quote
Old 02-23-2012, 08:32 PM   #6
sly the dogman
You're wrong Paul, it does help.
Thanks,
Old 02-23-2012, 08:35 PM   #7
sly the dogman
Its not the same heli, the one in september is totaled. bought this one as a bare-bone here on the 4 sale forum. But still its worth taking a look. I'll be installing a regular 500 size parts in the days to come, so upon
installation of the belt I'll surely inspect that avenue.
Old 02-23-2012, 08:43 PM   #8
buzzsaw 46
Sorry, I assumed it was the same machine. Hope you solve the issue, crashing from parts failure is no fun at all.
Old 02-23-2012, 09:44 PM   #9
belcom
Hey Sylvain, I can send some FB head parts to you if you need them. I got the head without blade grips or swash after the FBL upgrade. Everything else is yours if you want. Seems you're having some bad luck and that sucks. It's the first time I hear of a belt breakage on the 500. Don't mean to make you feel worse but since it happened twice now I would really look into the setup.
Team Compass
belcom is offline        Reply With Quote
Old 02-24-2012, 08:12 AM   #10
Pitbro50
Sorry
But stop spending your money on this heli.
Keep the electronic and buy this
http://www.ehirobo.com/shop/product_...oducts_id=6193
Pitbro50 is offline        Reply With Quote
Old 02-24-2012, 01:25 PM   #11
sly the dogman
Now you see, you just hurt me here. If you think Compass is
underneath this brand well.....I'll stay polite and not say another word.
But thank you anyway for your input, sir !
Old 02-24-2012, 01:30 PM   #12
DominicD
The Capi
Sorry to see that sly, I just hate mechanical failures. In my experience most belt failures are caused by the belt being too loose. What happens when the belt is too loose is the belt slap against eachother inside the boom, when they do the teeth engage eachother. Once the teeth engage eachother all that rotating mass would have to come to a stop which just isn't going to happen so the belt breaks instead. If when flying you hear a "ting ting" sound you know thats is the sound of the belt hitting the boom, a sign your belt is too loose.
DominicD is online now        Reply With Quote
Old 02-24-2012, 01:36 PM   #13
Ah Clem
Sly,
I am very sorry to hear this, my friend.
I wish I knew what was causing the belt issues.
My Atom still has its original belt from 2008 and that belt is in good shape.
I wish I could help you, sir.
Not sure what to do...
Ah Clem is online now        Reply With Quote
Old 02-24-2012, 01:41 PM   #14
sly the dogman
Thanks Dominic, I will surely keep that in mind, I knew too tight wasen't good but I never thought that too loose wasen't better, my bad. I can easely attibute the belt failure to this cause, mainly because I cannot see any other reason.
Constructive analyses is what its all about in this forum, that's why I'm here on this board and part of the reason I own a Compass heli.
Old 02-24-2012, 01:44 PM   #15
Ah Clem
Sly,
For what it is worth, I run the belts just tight enough to they do not slip a tooth. IMHO, it does not matter if they slap the boom a bit-this over hundreds and hundreds of flights on cog-belt driven machines for decades (literally-remember, I am older than dirt).
You would have to run the belt very, very loose to have that be the cause of the snapped belt.
An extra twist in the belt would cause the problem you experienced.
Old 02-24-2012, 01:51 PM   #16
DominicD
The Capi
I usually error on the side of being too tight
Sly you attending any funflies in my next of the woods this year ?
Old 02-24-2012, 02:14 PM   #17
lazor 22
Originally Posted by Pitbro50 View Post
Sorry
You gotta be kidding me I had a crapterX once and well there is a reason I call it that.
Lincoln
#HIGHONHELIS ):>
Pull Hard
lazor 22 is offline        Reply With Quote
Old 02-24-2012, 02:22 PM   #18
kelseh
I read that post this morning and I thought that maybe it was a joke. I never seen one in person but did you see the machine work on that thing. Just plain ugly.
Old 02-24-2012, 02:26 PM   #19
Pitbro50
I dont say that it's just a cheap replacement if you dont have the money for rebuilt the compass.
Old 02-24-2012, 02:50 PM   #20
sly the dogman
Sorry
Please gentlemen, let us not run with this, just let it be !
