Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-23-2012, 10:20 PM   #1
caralmar
Default This heli is built like a tank!!
So I plowed the ground today at full speed pulling out of a high-speed loop...ground came up too quickly! Impact sheared the head completely off the heli and split the headblock in half...
However, the frame and all electronics survived! The blade grips are also intact. Both main bearings are totally frozen up.
Here's the really interesting part...I never hit TH since it happened so fast, but the main gear is also intact! The batteries were nicely protected inside the frame cage and were not damaged.
My RH order came out to $180 not including blades, tail boom, boom braces, skids, and a few other things I had in stock. Not too bad. My buddy mtymyk witnessed the crash and we both commented on how amazing it was this thing survived the way it did... on just about any other heli, this would have been a rekit! I know it would have been with my 600ESP.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote
Old 02-23-2012, 10:35 PM   #2
OnTheSnap
A pretty normal crash broke the plastic servo moldings for me. Conclusion - every crash is unique.
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e
HeliDirect, GrandRC
OnTheSnap is offline        Reply With Quote
Old 02-23-2012, 11:56 PM   #3
what-d-heli
Woah! Sheared off that head and just minimal damage? Glad to hear the 600efl can handle some nasty crash. Not that I want to experience one anytime soon to prove it also, lol.
Hope you get it fixed and have her flying soon. Were you flying with Mike when it happened?
what-d-heli is offline        Reply With Quote
Old 02-24-2012, 12:07 AM   #4
Liduno
Kind of off topic but was that head advertised as billet?
Liduno is offline        Reply With Quote
Old 02-24-2012, 12:50 AM   #5
sprat0864
Hi guys.. I too was impressed with the machine. my one and only mishap with my 600 efl pro was full power + gravity + out of control Versus earth.... Earth won the battle. As u can see in the pic the wire in the blade wrapped so hard around the shaft it took me hours to get it apart. ( high tensile wire ) The main shaft didnt even bend ( replaced it anyway). So apart from Tail boom, skids, canopy blades and 1 Lipo (wouldnt take a charge after impact) the heli survived well. Very impressed... Am trying hard not to repeat the performance :-)
ID:	292824   Click image for larger version
sprat0864 is offline        Reply With Quote
Old 02-24-2012, 01:06 AM   #6
cortez jenkins sr
I agree. I love it for that reason.
cortez jenkins sr is offline        Reply With Quote
Old 02-24-2012, 02:22 AM   #7
HeliBenj
Nice one!
To the OP, I always thought the head block looks a bit skinny where it broke, hoping the new shorter DFC head block if beafier. Can also get a KDE block. But hey, the energy has t go somewhere anyway so something else will bend / break
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is online now        Reply With Quote
Old 02-24-2012, 03:26 AM   #8
daddoo
The more I see the heli crash picture the more I worry to fly my 600EFL. Due to the currency conversion in my country I have to pay 3 times more than you guys to repair the same damage.
But, touchwood!!!!!!!!!!!
daddoo is offline        Reply With Quote
Old 02-24-2012, 03:53 AM   #9
sprat0864
Shift to Australia mate, We are at $1.06 US at the moment. It's like heaven :-)
Old 02-24-2012, 05:15 AM   #10
satgod
just total up your cost if it gets to high start looking on ebay and the forums for a airframe
its what I did. if you pay 50-100 more than your actually repair cost you'll have parts for next time or can sell off the frames for the 100.00 and be even
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 02-24-2012, 09:07 AM   #11
caralmar
Yeah, Mike and I spent the entire morning flying, it was great! Unfortunately, we both plowed a heli into the ground...his 450 had some mechanical failure and got dirtnapped and mine was more of a depth perception problem.
I do those power loops all the time at my field, which is flat, but at Dyer, there is like a flat spot where you take off and then a small hill... well, I miscalculated the exit and didn't pull up in time to avoid the little hill.
I hope to get all the parts today and be back in the air this weekend... I'm hoping there is no damage to the servos or vbar!
AMA #934662
Old 02-24-2012, 09:31 AM   #12
HeliBenj
I just came back from a 3 flights session at my "alternate" (read non sacntionned next to the office) field and almost had a similar mishap. I love to make those big inverted loops in the pilot's awis (towards me and pull hard to make blades fart . On occasions I just make a turn at the end and go past me on the side. Just forgot this field has a tree line behind me Almost went full speed inverted into a tree and just managed to pull out before mayhem. That's what I call an adrenaline shot
Made it down safely though
Ben
DX8, RF6
Old 02-24-2012, 12:19 PM   #13
destroyerbmx
I feel like this would be an issue. When I put it together I saw its all plastic, while it looks smooth, I have not seen replacements and would think plastic strips easily. Have not crashed yet but I am not looking forward to having to get new side frames if this happens. Might get the copterX frame for the metal mounts if it breaks on me.
Looks like I can get just metal mounts and make it fit on the align frame (which I think would be higher quality and more precise measurements)
http://www.ehirobo.com/shop/product_...ducts_id=11437
destroyerbmx is offline        Reply With Quote
Old 02-24-2012, 02:29 PM   #14
caralmar
Alright, well an update... I just finished tearing everything apart (mechanically). Looks like all of the bearings survived except the main bearings. I put in some nice ceramic hybrids in there. Also, one of the blade grip links is totally missing, and I just looked at my stockpile of parts and I have the rods, but not these funky large plastic ball links! Even the ball link kit I bought for this heli doesn't have any! Where do I get those?
I'm still trying to wrap my head around this main gear thing. This is the first major crash I've had where the main gear survives intact...not sure how, but it did! I put the heli main body on the bench and powered it up a few minutes ago. Everything powers up fine and I get good smooth movement out of the servos. Spools up perfectly and zero vibration, so I got lucky!
Oh, here's a weird one... I'm missing the torque tube!!! Its not in the pile of wreckage we picked up at the field. The bearing holder AND bearing are both inside the boom, but the TT is gone!
Where the hell is the UPS guy!!! Bastard always makes my house his last delivery!
AMA #934662
Old 02-24-2012, 02:39 PM   #15
mtymyk
Carlos, you are one lucky mofo!! lol, Still very surprised how the heli survived, you would have thought it would have disintegrated. I almost wish I was taping, I think most would have been astonished. Btw, I will be at Dyer Monday to Wednesday, lol, let me know if you have time to hook up again. now go hunt down that UPS guy!!!
Logo600, 7HV, Goblin700, Goblin770 14s, Goblin 500
Vbar, Kontronik, JR, Scorpion
Team Rotorquest
mtymyk is offline        Reply With Quote
Old 02-24-2012, 02:47 PM   #16
caralmar
LOL! Yeah man, I've been pulling grass out of every possible hiding spot in the frame! Hey, I can't tell for sure, but I could almost swear that the main shaft AND feathering shaft are straight as an arrow! Don't ask me how that's possible... I threw both of them out just in case, but it is weird.
Mike, sent you a txt earlier, but I guess you didn't get it... want to do a Boynton Fun Fly again this Sunday? Fly for a couple of hours and then BBQ at my house. Bring the wife and kids!
EDIT: HOWWWLLLLY CRAP!!! He just showed up! Ok, gotta go get busy rebuilding!
AMA #934662
Old 02-24-2012, 02:53 PM   #17
caralmar
EDIT 2: LMAO... ReadyHeli RULES!!! LOL I told them to ease my crash pain with extra mints...
AMA #934662
Old 02-24-2012, 04:02 PM   #18
mtymyk
I guess we'll be having some mints after the FunFly BBQ?!!! lol
Team Rotorquest
