Go Back   HeliFreak > For Sale Forums – KNOW your buyer/seller ratings! No Price bashing. Work out price details via PM. > Gas, Glow and Turbine Helicopters
Gas, Glow and Turbine Helicopters *No Commercial Ads - Liquid Fueled Helis Only
Closed Thread
Old 02-24-2012, 07:34 AM   #1
belcom
Default Compass 3D+ FBL Nitro Airframe + all servos
The 3D plus is the next generation high performance 50 size heli. 300 grams lighter than the Knight 3D, which was already one of the lightest in its class, the 3Dplus has a better power to weight ratio than any other helicopter on the market! This heli flies like no other. With the all new rotor head the 3Dplus can handle anything you throw at it with the usual Compass Model crisp and presice feeling.
Features:
New Rotor Design
Increased Cyclic Speed
Large Pitch Range
Metal Swashplate 120° CCPM
Precise Control
Extremely Lightweight Frame Design
Easy Maintenance
Easy Assembly
Anti Vibration Engine Mount
Improved Engine Cooling System
Fully Ball Raced
Fully Equipped with Thrust Bearings
Hardened Main Shaft
8mm Spindle Shaft
Hardened Tail Shaft
Front Mount Tail Servo
Proven Belt Driven Tail Rotor
Dual Pin Zero-Slop Tail Pitch Mechanism
Specifications:
Length: 1270mm
Rotor Diameter: 1360mm
Gear Ratio: 8.66:1:4.8
Weight: 3.15kg
Engine Size: 50 to 57
Rotor Blades: 600 to 620mm
Comes with a header tank, carbon fibre tail boom, extra fuel tank with clunk, stock plastic and extra set of CF tail blades.
I also have a full set of servos for this helicopter
3 x Hyperion DS20X-SMD for cyclic
1 x Hyperion DS20X-GCD for tail
1 x Spektrum H6010 for throttle
1 x Hyperion USB programmer interface
It is a very nice flying helicopter and is capable of hard 3D but can be setup to your liking. Very stable, quick cyclic, very nicely designed and machined Compass FBL head, zero slop tail system. Hyperions are very nice servos, cyclics are 16kg torque and 0.11ms speed at 6v, have zero gear slop and work wonderfully.
Original price for airframe was $470
All Servos about $250
Plus misc parts
I'm looking for $300 for the airframe with extras (No main blades included in the sale)
$150 for the servo package (including all Hyperions, programmer and Spektrum throttle servo)
Shipping extra. But would be nice if picked up locally in Woodbridge, ON, Canada (for canadian local buyers)
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5
RCHeliCanada.com - Compass Model - Synergy - Scorpion - MKS Servos - YGE - Kontronik
belcom is offline
Old 03-03-2012, 10:26 AM   #2
belcom
Bump. Somebody must need an awesome flying, lightweight and reliable nitro. Modern design, excellent FBL head design, zero slop tail system. Only from Compass
I have an extra Hyperion DS20X-GCD tail servo I will throw into the deal. Additional $50 value. So you will have 2 of them for backup if you break the first one or use it somewhere else. It will work great on any 600 or a 500 that takes a full size tail servo.
The Hyperion servo programmer I am including allows you to adjust the servo itself for ideal 90 degree horn position (perfect center) without touching anything in TX. That's right! No trim needed on the TX to achieve a perfect setup.
Also not shown on pictures but I do have servo horns and mounting hardware for the servos as well.
belcom is offline
Old 03-18-2012, 12:40 AM   #3
lazor 22
Bump for a awesome heli!!!
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies
7HV, Warp, 3D+
Lincoln
lazor 22 is online now
Old 03-18-2012, 12:13 PM   #4
belcom
Thank you Lazor!
Need some cash for a honda generator guys. Shipping cost will be around $40-$50 to US. I will pack it well in the original box and wrap the box with some packaging paper. Box dimentions are L30xW10xH6 the weight of the box will be around 4.5 - 5kg I think. I can calculate more accurately for those who are interested.
Can include a BeastX for additional $160.
belcom is offline
Old 03-18-2012, 08:05 PM   #5
Down Low
Hmmm... How much you figure to ship to Calgary, Alberta? Just the air frame?
This could possibly save me some coin on converting my 3DP to FBL AND I would have a spare part for everything
Airtronics SD10G, SK540, OS.50 Hyper (possibly tweaked a little)
Synergy N5c
MAAC #85462
Down Low is offline
Old 03-18-2012, 08:21 PM   #6
belcom
Canada Post Regular Parcel (6 business days)
Not insured: $28
Insured for $300: $35
belcom is offline
Old 03-18-2012, 08:49 PM   #7
Down Low
K. just on my way into work, not much time atm. What is its history, air time? Crashes?
Looking like I just may HAVE to take this off your hands.
Synergy N5c
MAAC #85462
Down Low is offline
Old 03-20-2012, 06:36 PM   #8
Down Low
Payment sent for the air frame. Thank you!
Synergy N5c
MAAC #85462
Down Low is offline
Old 03-20-2012, 08:59 PM   #9
belcom
Airframe sold. Thank you Dave! Servos will be listed separately.
belcom is offline
Closed Thread
