Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 01-08-2005, 03:27 PM   #1
Dash
Default Spectra-G Tempest Blade mount problem...
Well I just finished assembly the rotor head assembly. I then was going to temporarily install the two blade bolts, lock nuts and blade spacers. Thats when I saw that one of the machined blade mounts has both the top and bottom holes machined to take the hexagonal locknut Anyone else run into this problem? Can I use a dremel tool to smooth out the edges so the blade bolt will drop in or do I need to get a replacement blade mount?
Dash is offline        Reply With Quote
Old 01-08-2005, 05:31 PM   #2
ddavison
If you are not in a hurry to get in the air, call them and send it back. If you are in a hurry there would be no problem I could see dremeling it out. Dave
Dave Davison
GasGob,Whiplash Gas,Fury55,Spectra
JR XG11MV,12X,CGY750
ddavison is offline        Reply With Quote
