Old 02-29-2012, 09:45 AM   #21
onlocation
Our Logo600se flies on 710mm blades at 1500-1600 rpm at 18lbs/8kg. I've flown in temps well below 0F/-20C. I was worried about the plastic getting brittle but I haven't experienced any problems yet.
As far as optimal payload for blade size, in my humble opinion you want the heli to be at the upper weight limit that you are comfortable auto-rotating. The heavier the disc loading the better the heli handles turbulence.
onlocation is offline        Reply With Quote
Old 02-29-2012, 09:19 PM   #22
cbergen
+1.
Smaller blades CAN carry good payloads, but they will auto like a cement truck...
Chris D. Bergen
Bergen R/C Helicopters
cbergen is online now        Reply With Quote
Old 02-29-2012, 11:07 PM   #23
Cirkus
...or glide like a manhole cover.
FlightCam
http://ryanbarnes.smugmug.com/
Cirkus is offline        Reply With Quote
Old 03-01-2012, 02:37 AM   #24
MaSt0RaS
So on 750 i will be ok on 8.5-9 kilos right??
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote
Old 03-01-2012, 10:22 AM   #25
onlocation
It will work but I would suggest you are better off on the 700 size blades. Trex700 A/P machines commonly fly in the low 20 pound range on 700's and do really well.
Old 03-01-2012, 10:53 AM   #26
MaSt0RaS
Yeap i agree but on 700 you auto 7-8kg... with 750 you can auto 9-9.5kg Ships..!
Old 03-01-2012, 10:56 AM   #27
onlocation
You can auto 10kg on 690's, ask me how I know.
Old 03-01-2012, 11:03 AM   #28
MaSt0RaS
OUps....
N1... OK then i will add some more weight and i will kieep the 750 a like them a lot more than the 710 that i had
I dont ask you how you know ..... its what i am thinking??!
Old 03-01-2012, 11:23 AM   #29
onlocation
Just remember there are a lot of factors when considering auto rotations. In full size helicopters there is something called a "dead man's curve", it's basically a curve on a height/speed graph where if you are below the curve, then you won't have the energy to do an auto rotation. Basically the slower you are flying, the higher you need to be; and the lower you are flying, the faster you need to go in order to successfully auto rotate. Weight and disc loading are huge factors in this graph.
As we increase the weights of these A/P machines we are starting to see more full scale behavior (more so then even "scale" r/c helis). Dead man's curve and transitional lift are really important to understand for a successful auto rotation or just successful flight on a heavy A/P machine. For example coming out of a steep decent with a very heavily loaded helicopter is not as easy to do, you need to carry speed and fly it out of the dive more like an airplane, similar to what a full size helicopter will do.
When you fly a heavy A/P machine you may at first think, wow this feels really heavy, but that is because you are still flying it like a normal model helicopter. When you start flying it like a full size helicopter you will be amazed at how much weight you can really carry and still have a good margin of control.
Old 03-02-2012, 08:01 AM   #30
cbergen
Exactly correct! Good advice.
Chris D. Bergen
Old 03-02-2012, 11:15 AM   #31
xfc3dcd
Smile
Or to quote another, "a stable AP machine handles like a school bus fully loaded with fat kids"
xfc3dcd is offline        Reply With Quote
Old 03-13-2012, 04:38 PM   #32
maximus210
Default fat kid AP
Love it I will use that if I may very funny but true
maximus210 is offline        Reply With Quote
