Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-26-2012, 02:01 PM   #1
fusionbrad
Default Lowering Head
is anyone using the middle or top hole on the head?
i want to drop mine to the middle hole but just checking if anyone else is running it lower.
fusionbrad is offline        Reply With Quote
Old 02-26-2012, 05:22 PM   #2
Discount_Bob
I read somewhere that some folks have successfully used the middle hole with no modifications. I'm sorry I don't have any more info than that.
-Jay
Discount_Bob is offline        Reply With Quote
Old 02-26-2012, 06:38 PM   #3
im4711
not really sure about no modifications since you would have to use shorter linkage rods.
im4711 is offline        Reply With Quote
Old 02-26-2012, 08:27 PM   #4
backburner1955
Why couldn't you use the top hole and just change your pitch links to turnbuckles of the correct length. Just use link rods that are shorter by 10mm. If one is worried about geometry changes, then change the 3 swash links to ones 10mm shorter.
I already use 60mm seacraft pitch link turnbuckles on the F50 head on my Outrage 550, I would just need 50mm turnbuckles.
http://www.espritmodel.com/pushrod-t...raft-m3-2.aspx
AMA# 982814
backburner1955 is online now        Reply With Quote
Old 02-27-2012, 12:46 AM   #5
Discount_Bob
By no modifications, I meant no grinding, cutting, or drilling. Changing link lengths is pretty simple.
-Jay
Old 02-27-2012, 10:33 AM   #6
Michaelinpr
All you would need to do is cut 5mm off each end of the linkage rod. Mine have plenty of thread on them.
The thing I would worry about is a boom strike. I have seen a few as stock. I think this was the dampeners but this mod may add to the possibility.
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650
GAUI XB5-EXTREME 12s
, Scorp HK-4025-550/CC 80HV, 610's, V Bar/650
AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV
Michaelinpr is online now        Reply With Quote
Old 02-27-2012, 10:51 AM   #7
fusionbrad
i will be running kbdd green dampers, so i dont think it will boom strike if i move it to the middle hole
Old 02-27-2012, 10:53 AM   #8
backburner1955
I know there have been guys flying the F50 head on the O550, in the lower position and have had no problems, or boom strikes.
AMA# 982814
Old 02-27-2012, 02:20 PM   #9
Wh1teAfr1can
you shouldnt need to change the dampers. If you are having boom strikes your blades are too lose in the grips.
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Gaui X5 Kontronik 100 lv, Beastx
Wh1teAfr1can is offline        Reply With Quote
Old 02-27-2012, 02:26 PM   #10
hndaluvr
There are NO mods needed in order to run the stock F50 using the middle hole.
I've used that location from the very start (2nd batch released to the market). The pitch links have plenty of room to thread in deep, and zero pitch setup is easily achieved. No other adjustments needed.
This is an old topic, and I thought MOST were using this middle hold?
The top hole?... now that's a different story, but shorter pitch links solves that issue too.
hndaluvr is offline        Reply With Quote
Old 02-28-2012, 03:19 AM   #11
fusionbrad
Im not modding anything, im adding the kbdd dampers anyway cauz i love them on every heli iv tried them on, so they going on anyway.
thanks for the input guys, i will try it on the middle hole and see how it goes
Old 02-28-2012, 10:42 AM   #12
hndaluvr
You mentioned that you'll be runnin' KBDD lime green dampers?
Give it a try... but most of us that have tried 'em have suffered from either low-speed or high-speed excessive vibrations. They are wayyy too stiff for this heli. The orange and yellow ones seem to work better, but the Stock ones work perfectly for all types of flying.
Old 02-28-2012, 10:46 AM   #13
Wh1teAfr1can
they seem to work well in all Align helis but they are too hard as hndaluvr mentioned for the outrage machine. if it isnt broken dont fix it.
Team Kontronik
Team minicopter
Old 02-28-2012, 12:57 PM   #14
fusionbrad
ok thanks guys, will do some tests and see. i ordered the blue and lime green ones so i will try them both, if stock is best i will stick with it
Old 03-01-2012, 08:36 PM   #15
HugoCraft
I'm on the middle hole with no mods at all. I'm running the BLUE kbdd dampners which are very stiff and take a decent amount of effort to get in.
HugoCraft is offline        Reply With Quote
Old 03-03-2012, 07:27 PM   #16
AeroMattics
Is there a noticeable difference after switching the head height by 5mm from the bottom hole to the middle?
I set mine up per the manual and don't recall any recommendations regarding using the other holes. I figured the additional holes were there for those who were using the fbl head as an upgrade on other models...
Compass 7HV
Compass Atom 500E
Outrage Fusion 50
AeroMattics is offline        Reply With Quote
Old 03-16-2012, 03:46 AM   #17
Martyn (Bomber)
What size blades have people been using while set in the middle hole of the head ???
Are you limited to 60? Blades at this height ???
Martyn (Bomber) is offline        Reply With Quote
Old 03-16-2012, 10:18 PM   #18
HugoCraft
I'm running edge 623mm which are the same as other brand 630mm
Old 03-17-2012, 08:15 AM   #19
Martyn (Bomber)
And that's in the middle hole position with stock black dampers HugoCraft ???
Old 03-17-2012, 09:07 AM   #20
Discount_Bob
He's using blue kbdds.
Sent from my Kindle Fire using Tapatalk
-Jay
