Old 02-26-2012, 02:22 PM   #1
jackp1
Question GWS 25A BRUSHLESS ESC
just a query i bought a speed controller for my rex250 i bought the GP780 gyro & the Align 20A RCE-BL20 ESC.
well the gyro seems fine, set up easily enough, but the Align speed controller is doggy i tried to program it & it does the first 3 stages then goes into the 4th stage were if i'm correct the throttle stick should be at mid for helicopter, you move stick to center & guess what happens it beeps some type of alarm after about 10/15sec.
you unplug it & touch the speed controller & it's red hot, it's nearly melting the yellow heat shrink around it. so i move throttle stick back to down position plug in esc it goes through the first 3 stages & stops no more beeping anything.
so is it faulty i have a linear throttle curve it's a brand new dx6i radio & ar6210 receiver & speed controller for that matter, even the batt's are the brand new thunder power G6 pro power 65C 850mah, iv not got round to using them yet so i can't tell you what they are like.
i no i have bought a new speed controller i went for something completely different i have purchased the GWS 25A ESC WITH 5V Bec & speed controller it only cost 20 qid for the 2 posted i found 1 on sale they are only 10 qid each & brand spanking new just a shop sale if your interested just pm me i will send you the web site link. so are these speed controller any good on a rex 250 comments welcome thanks for looking jack......
Trex-500 CF Scorpion 1400kv motor,Stock ESC, HS5245 spartan760-9257 Hercules 5/6v switchable-BEC, 4 Align 2600 6s batts, bantam BC6 dual power 6s lipo chrger DX7
Apache 9088
twin helix
jackp1 is offline        Reply With Quote
Old 02-27-2012, 07:57 PM   #2
jackp1
so no one has any thoughts on using this GWS 25A- ESC on their 250rex, aah now i remember why i stopped using this forum, there is quite a lot of members who ignore you most of the time. ah well heliguy here i come at least there someone will chime in a comment or 2. later american dudes
Apache 9088
twin helix
Old 02-27-2012, 09:52 PM   #3
JoeW
Don't go away cranky....
I for one don't typically comment if I have no experiance. I'd suggest most folks here opt for a CC25 for the 250s and wouldn't have much experiance with Align ESCs other than the 15 that comes with the 250 or the 35 for the 450.
Do you maybe need to calibrate the radio's endpoints to get setup to progress any further? Have you tried pulling the red wire from the servo plug to see if it still gets crazy hot during setup?
The 250 shouldn't really pull more than 12-14A, and never for very long... the only reason I stepped to the CC25 was for the features. It's nice to have a little headroom though.
TRex 250 DFC | TRex 250 DFC (Scale)
2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale)
TRex 550 DFC
DX8 + Telemetery on all
JoeW is offline        Reply With Quote
Old 02-28-2012, 03:06 PM   #4
jackp1
my align 25a esc wasn't even spinning blades just going through the set up process, by the time you get to stage 4 on esc set up.
you leave throttle at mid stick for helicopter after you do this it then starts beeping some kind of alarm so i unplug battery & that's when esc is nearly melting my hand, it's that hot it got sent back yesterday & today he emailed me to phone him i got my gws esc 25a plus the programing card once my small deans connectors come i will be able to solder it together plus it has a 5v 2a bec attached then fingers crossed it will work & just in time for the Hyperion upgrade motor i ordered yesterday it's currently in the post i recon another month & it will be FBL
Apache 9088
twin helix
Old 03-09-2012, 08:39 AM   #5
shadco
I would be a little concerned about a 2 Amp bec.
On my Gaui which is similar to the T 250 I used a CC 25A , and a CC 10A bec. The Bec on the CC25 is 3A and the castle guys felt 3 amps is borderline with a beastx fbl controller.
Diabolo 550 Vbar NEO : Diabolo 700 Vbar NEO: MSH Protos MAX V2 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is online now        Reply With Quote
Old 03-09-2012, 09:45 AM   #6
JoeW
I did some bench tests with a 3GX and some good step mode BECs, a 1.5A and a 3.0A
Long story short, I could easily get the 1.5A to fail with Rx/3GX reset with even smal, rapid pitch movements on the bench. I could reproduce it within about 10 seconds flat.
And that's with a very good, solid 1.5A SBEC, which ran a stock 250SE without much concern. If that's a 2A linear BEC, you certainly don't have any headroom, and would be in the warning area IMHO
TRex 550 DFC
