| mQX Blade mQX Quad Helicopters Information and Help |
Just wondering what you all thought of these and how well they might work, plus wanted to post them in case others were interested in trying them...feel free to post other options too.
I already ordered 1 each of the first two to try, not sure the extra weight of the 1000mah is worth it since it weighs about 4 grams more then the 900mah and has 15c instead of the 25c of the 900mah, so not going to order that one for now. Lectron Pro 3.7v 600Mah 35c Lipo Battery UPGRADE for Blade 120Sr MQX BNF/RTF New http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1413 3.7v 900mAh 25C Lipo Battery RC Helicopter For Walkera HM-V120D05-Z-25 M120D01 http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1348wt_1163 GENS ACE 1000mAh 3.7V 15C LiPo Battery http://www.nitrorcx.com/98p-15c-1000-1s1p-wk.html |
The Lectron Pro is a nice battery. I use them. Don't know about the others.
I am useing the Hyperion 550s
Trex 700n DFC Beast x...Trex 600n Beast x... Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50 MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx Blade 300x Phoenix 25esc Park BEC Blade upgrades Ducati Desmo 1/5 scale nitro superbike |
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1413 3.7v 900mAh 25C Lipo Battery RC Helicopter For Walkera HM-V120D05-Z-25 M120D01 http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1348wt_1163 GENS ACE 1000mAh 3.7V 15C LiPo Battery http://www.nitrorcx.com/98p-15c-1000-1s1p-wk.html[/QUOTE] (This maybe a newb question) With the "max cont discharge rate" on the 35c and 25c... Does that have the potential to fry the board? I'm not used to not using nothing but stock Lipos... |
Nope. That is just the batteries potential. The board only takes what it needs. However it can only take as much power as the battery can provide.
Sent from my DROIDX using Tapatalk |
#6 |
#7 | |
I'm already running hyperions and they are 25c, so I'm guessing that is fine atleast...I'm glad to hear others saying more c is ok though. My guess would be the lectron might be best overall because of the lower weight, the 900mah i listed is like 24 grams I think, and the 1000mah was 28g if I remember right I can't find the weight of the lectron, but i found another battery with the same stats that is 14g so I'm guessing the weight is similar.... here is that one and another i ran into... Tigers 1S 3.7V 600mAh LiPo Battery Blade 120SR EFLB5001S http://www.ebay.com/itm/5x-Tigers-1S...ht_2134wt_1163 Forcehobby 1S 3.7V 600mAh LiPo Battery Blade 120SR http://www.ebay.com/itm/5x-Forcehobb...ht_2136wt_1163 Both those are only 15c though. Oh also found this one with same stats as lectron... Flytown Blade 120SR 1S 600Mah 35C Li-Po Battery http://www.ebay.com/itm/Flytown-Blad...#ht_834wt_1163 |
#8 |
I've been using the inexpensive Tiger packs and have found them to be more than ample for 5 min. aggressive flights with my 120sr. I've flowen 25 cycles pn each with no sign of failure so far. They blow the stock batts away for value and will be buying some more without hesitation.
#9 |
Here is what I did! I got the Ultra Micro Battery Adapter for the mcpx and replaced the adapter on the MQX. Now I use the same batteries I do for my mcpx. I only fly it 5 minutes and any longer ADD kicks in.
Ricky
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
I have the lectron pro and hyperion batteries. Hyperions have a slight edge when it comes to performance, but the lectron pros last forever! I flew one of them for 15 minutes before LVC kicked in. They are great batteries in my opinion and they are still cheaper than eflites and way better overall.
#11 | |
These are pretty awesome. More kick for longer. Plus I got these for $8 a piece which is a steal. Can anyone suggest a good multi charger? If possible I'd love to charge four batteries at once.
| 120SR | |
#12 | |
I use ....... see thread I've had these a couple of weeks now, very pleased. Shipping time was a killer but sumtimes it bees dat way
Blade mSR X, mQX,CX2, 120SR / Spectrum DX7 PZ Night Vapor (plank, actually, flying stick) Blade mSR(drowned in pool) To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. E-Sky HBCP2 - current condition ... DIB (dead in box) |
#13 |
I am surprise the Turnigy NanoTech 600mAh hasn't been mentioned yet? It's long like the Lectron. And works well from my experience so far.
Not all NanoTech are good. But the 600mAh seems great for the money. |
#14 | |
600s work well for the MQX, but the batts may not last as long as expected. Not complaining, mind you. Good overall experience. Hyperion 550s have fewer mAh but they are very good quality batts. You can charge them at 5c (quick charging) and they are lighter as well, top marks!
A few little birds... |
