| Electric Micro/Mini Helicopters Electric Micro Helicopters Discussion |
Hi Helifreaks out there !!
This thread is gooing to all Solo Pro 100 3D owners and with once they want to become one... ![]() I am since a fiew days owner of one of this Micro Helis ... was tired to wait for the Trex 100 3G. I was only flying indoor for the moment - this are my experience for the moment: In normal Mode the heli is really freaky to fly... not the best stability for newbys... But in the 3D Mode everything is much better and it flys really very nice and also stable.. I am using 300mAh Turnigy Lipo and get arround 4 Minutes of flying - hoovering in the room. maybe would be good to have a little more pitch for outdoor flying.. flying arround with a lot pitch to hoover normal and inverted.. Inverted is a little better... Maybe the stock setup of the radio is not really perfect.. Anybody tested some different settings out there ?? Inverted flying is really stable.. maybe better than with the Blade... Pixs will follow soon.. Would be lucky to find some Solo Pro 100 3D Friends out there Cheers Joe
Radio - Hitec Aurora 9 - 2.4GHz T Rex 700 Electric - 700MX 470Kv - Hobbywing Platinum Pro 120a HV - DS 610 - JR G770T / S9254 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. T Rex 550E - BL 600MX - DS610 - JR 770T /S9254 - Hobbywing Platinum Pro 100A |
Just ordered mine. I was having so much fun with the Solo Pro V2's I figured I would give this micro a try. I will post more after it arrives this week.
Hi there !!
Have changed different pitch settings for 3D Mode... had to reach up the max a little bit because at outdoor flying it was to less max Pitch.. have changed the curve to 25-37-50-63-75 now it is much better !!! Some more experience will follow soon Cheers Joe ![]()
Mine shipped today! Can't wait to get it.
Are you running any expo for cyclic controls? |
Mine is on the way! Very exciting! I've flown a v200dq01 Walkeria and a WLtoys v911 for a few weeks now, so this will be my first cp heli.
#6 |
Quick & list of stuff I've gleaned from the RCGroups SP100 forum + my own experience in the past week of ownership.
I crashed the sh*t out of it in this first week despite having a decent amount of 4ch skill (i was pirouetting my old 9958 through car interiors). But it's been a great first 6ch CP heli to me, and with the $80 HobbyKing deal, I could not have asked for more. Even with the CF skids, mSR swash & links, 2 extra batteries & a couple sets of spare parts, I think I'm still under the price of an RTF mCP X. The heli's main weakness is lack of parts support in the US, hence my ghetto-rigging of the mSR upper swash. But that's peace of mind, because I'm no longer afraid of breaking and losing the swashplate balls. mCP X main blades, KBDD mCP X blades, mCP X tail motor & rotor all fit without much modification. |
#7 |
I just order mine from HK USA, hopefully receive in a week. I also order 3 Nanotech 300mAh.
#8 | |
Are you still thrilled with the SP 100? The Mini CP has been classified as almost being "indestructible", but if the SP 100 is easy to fix (and more importantly I can source parts locally or in the US), then I'd have no problems adding another Nine Eagles to the hanger. With that said, my initial task is to determine how many Blade parts can be substituted for replacements. I've seen that the MCPx main gear can be used with the SP 100 and you indicate that the MCPx skids can be fitted to the SP. Are there other MCPx parts that work with it? |
#9 | |
The mCP X main gear will fit but you have to modify the motor mount, as the mCP X gear is smaller than the SP100 gear. There is nothing direct-fit from the mCP X besides the main blades & the tail motor/rotor...don't know about the tail boom, though. However, I still love it, it's taught me so much about flying 6ch and I'm at the point where I'm doing stall turns and hovering nose-in pretty well...still have yet to try inverted but since the last time I tried it I broke dogbones and the swashplate...I'll wait until I have every upright orientation down like the back of my hand |
#10 |
Just received mine, heard about the skid so I checked out how flexible it is and it broke just within 5 minutes I received.
#11 |
Pardon my newbie question, when you guys said the G.S switch up is away from you or toward you holding the tx. Thx,
#12 |
Hi I reset my tx and wanted to know what do you use for pitch curve, expo, high and low DR and your gyro also what does the g.s switch do? i know its for the gear speed but what does it do?
#13 |
I give up and want to sell mine. Pls click on this link and PM me if interested.
http://www.helifreak.com/showthread....63#post3992663 Thx, |
#14 |
When the blades are NOT turning and the elevator and aileron stick is moved the swashplate moves accordingly and returns to center position when the sticks are released and move to center.
However, when the blades are turning and the elevator and aileron stick is moved the swashplate moves to where it is supposed to. When the sticks are moved or released to center position the swashplate does not move to center and you have to move the sticks in the opposite direction to have the swashplate move in the opposite position. All other heli's that I have when the aileron and elevator sticks are released with the blades turning the swash plate returns to the center position. I have no idea what is going on and how to correct this. I don't think this is normal. I do not fly in 3D mode and just went over to CP heli's after flying fixed pitch for a year. I have a Walkera Genius CP helicopter and it does NOT have this problem. The swashplate returns to center positon when the elevator and aileron sticks are released and spring back to center postion. Any help would be appreciated. I am about ready to throw these Nine Eagles Solo Pro 100's in the trash because of this. Thank you for any help in this matter. |
#15 |
here's mine with canopy painted white.
hkrc tail motor holder (for msr mcp x) and round aluminum tail boom made from a knitting needle. also has head damper kit for the mcpx. |
#16 | |
just checked mine, as i never really paid attention to the swash movement, it does this just a little as well and its normal i think, and flies great in normal and idle up mode. the genius in beginner gyro mode probably self corrects more and that's why the swash moves back to center. the solo pro 100 like most cp helis does not self correct, it just keeps going the last way you had it going until you make a change on the sticks though you'd figure if you let go of the stick it would move right back. but anyway mine does what you're describing a little bit (doesn't totally center the swash) and flies around normally. |
