Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 02-27-2012, 03:48 PM   #1
twentyafter
Default Scorpion ESC Question
I have the scorpion commander 45 amp ESC on my 450 Pro running a 2221-8. After a recent crash I spooled her up only to find the soft start is no longer there. Other than that it seems to operate normally. I have not had the time to go through the programming again, but I will see if it will take.
Any ideas? I have crashed this several times and never had a issue, no physical damage or impact that I am aware of. I have it mounted on the bottom of the frame and it is fairly well protected from impact.
Team Lynx Heli
Warp 360 / Chaos 550 / 130X
AMA # 971952
twentyafter is online now        Reply With Quote
Old 02-27-2012, 09:27 PM   #2
flerpie
1st assumption is that the ESC lost it's programming for whatever reason.
There is no problem until it's been proven that ESC programming is correct.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
