Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-27-2012, 07:48 PM   #1
mswify
Default Fusion 50 vs Beam AvantGarde 600
Guys,
I'm buying a new Heli and I'm limiting my options to the Fusion 50 and the Beam 600,
I really can't decide, and the reason that I'm a bit biased towards the Beam is the gears stripping problem with the fusion, I need your help on this one guys
I'll be using the below equipment:
  • Jive80
  • Vbar
  • Scorpion 4035-560
  • Cyclic 8717 - Tail 8900
mswify is offline        Reply With Quote
Old 02-27-2012, 07:50 PM   #2
irishmatt18
F50... So versatile. Can make it smaller or run bigger blades.
irishmatt18 is offline        Reply With Quote
Old 02-27-2012, 08:08 PM   #3
Slyster
Stripping issues have been solved with the new CNC delrin gear and see the sticky for more info on TT gears. Its a solid heli now even when over powered with 700 sized motors etc. and with Tareq and Berk Kammerer on board the future looks promising.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is offline        Reply With Quote
Old 02-28-2012, 08:00 AM   #4
mswify
So the new CNC delrin gear included with the new kit? or I'll have to buy it separately?
Old 02-28-2012, 08:05 AM   #5
Carapau
The CNC gear would have to be bought separately however I truly feel that if you are sticking to a 600 class motor there is no need to use the CNC gear. The issues of shipping tail gears should now be a thing of the past.
Trying to put all bias aside, I adore my Fusion however the Beam looks like one hell of a machine. Have a look on their forum to get a good feel of how it is getting along.
Logo 700, Logo 600, Forza 450EX, Trex 470L, Jeti DS-16, couple of planks and lots of laughs
Carapau is offline        Reply With Quote
Old 02-29-2012, 08:52 AM   #6
mswify
Guys, I'll buy the F50, but I need to ask you what pinion to use?
is this one (Steel Pinion 15T 0.8M 6MM Shaft) OK?
Old 02-29-2012, 08:58 AM   #7
senzafine
If you run the 560kv motor the stock pinion that comes with the kit should be perfect. It's a 13 tooth. I run my headspeed @ 2150 using it
Sent from my SPH-D710 using Tapatalk
MSH USA | KBDD Blades | HeliDirect | JR Americas
MSH Protos V2 | Protos 380
senzafine is offline        Reply With Quote
Old 02-29-2012, 09:23 AM   #8
mtymyk
best way to check is to use this headspeed calculator http://www.readyheli.com/headspeed-calculator.html
using the Jive in Mode4, whatever headspeed you wish to run, try to keep the TC% between 60-70%, this HS calculator will be helpfull
Team Rotorquest/ SAB Heli Canada
mtymyk is online now        Reply With Quote
