Old 02-29-2012, 04:02 PM   #1
KSTT325
Default Help, with futaba ciu-2
Please, I need help downloading the drivers for the ciu-2. I am running windows 7/ 64 OS.
I have tried just about everything I know. Called futaba 3x, they were useless. If anyone
out there knows the steps to install the drivers. I would very grateful.:arggg
KSTT325 is offline        Reply With Quote
Old 02-29-2012, 06:53 PM   #2
Al Miessner
I totally agree with you. I have identical OS running on an ASUS. Same issue, nother buddy has OS 7 but 32 bit and it works fine.
Flying Hard makes it fun (AnimAL)
GrandRC Team Pilot
Al Miessner is offline        Reply With Quote
Old 02-29-2012, 08:21 PM   #3
kcordell
With Windows 7 it can be a bit finicky.
Keep trying, only use 1 USB port, don't switch around thinking that's the cause until after it loads properly.
Took me 3-4 times to get it to work on Windows 7.
Team Futaba, Team Miniature Aircraft, Team Flightpower, Radix Blades, VelTye, YS Engines
kcordell is offline        Reply With Quote
Old 03-01-2012, 05:15 PM   #4
scotty82
Hi,
I had this problem when I first got my CIU-2. I am running Win 7 64 bit on my laptop. I downloaded all the drivers and software for the CIU-2. I opened up the software and plugged it in and the LED wouldn't go Red or Green.
I tried plugging in to different USB ports and it still didn't work. I deleted everything and removed the drivers. I re-downloaded and installed everything again.
I plugged in the USB and Windows downloaded the drivers for it to run the device. I then opened up the GY Link and Update software and the LED went from Red to Green and it worked.
I can plug in to different USB ports now and it works no problems.
I don't know what it was becuase I did everything the same on the second attempt.
Cheers
Scott
scotty82 is offline        Reply With Quote
Old 03-02-2012, 07:46 AM   #5
kcordell
The software is just finicky with W7. Futaba Japan knows of this issue.
