Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 03-01-2012, 05:41 AM   #1
zeeflyboy
Default KDE 600XF-530 HP
Just got this in an email from KDE - the specs, price etc are finally up. Should start shipping by the end of the month (they said 26th March in the email)
Looks like a monster! nice to see spare shaft and bearing sets are readily available too.
http://www.kdedirect.com/KDE600XF530.html
Price: $269.95
Material: Neodymium N45SH, 530Kv
Models: direct bolt-in design for the ALIGN 600E PRO series (M3 x 25mm). Also suitable for other 550,
600 and 650-class helicopters (compatible with M4 x 30mm and M3 x 25mm mounting profiles).
Motors include 200C, 13AWG silicone-wire leads and 5.5mm CC Bullet Connectors (pre-soldered to the
motor leads and ESC bullets in the box).
Kv 530 rpm/V
Maximum Power 7,500+ W
Maximum Efficiency 91%
Optimized Voltage 44.4 V (12S)
Voltage Range 37.0 V (10S) - 44.4 V (12S)
Io (@10V) 1.2 A
Rm (Wind Resistance) 0.017 Ω
Rotor Poles 10 (12 Pole Stator)
Bearings Quad, 696ZZ/MR106ZZ
Mount Pattern M4 x 30 mm, M3 x 25 mm
Stator Class 3538, 2Y
Shaft Diameter 6 mm
Shaft Length 41 mm
Motor Diameter 46 mm
Motor Length 62 mm
Motor Weight 410 g (430 g with Wires/Bullets)
Cooling System High-Volume Radial Fan
ESC PWM Rate 12 - 16 KHz
Glad to see we finally have a high power, quality, direct drop in replacement option!
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote
Old 03-01-2012, 11:16 AM   #2
NRPY
2Y windings are supposed to be better, right? I thought I read somewhere this winding configuration has less internal losses and it's easier for ESCs to deal with. Means no KSA mode with Jive ESCs.
NRPY is offline        Reply With Quote
Old 03-01-2012, 01:27 PM   #3
zeeflyboy
Absolutely no idea
Old 03-01-2012, 01:31 PM   #4
NRPY
You should get one right away, zee.
Then report back with power and vibe comparisons.
Old 03-01-2012, 03:17 PM   #5
zeeflyboy
I will - I get a bonus along with this months pay check on the 25th.... serendipity?
Old 03-04-2012, 02:14 PM   #6
taoY
I finally got the chance to fly the pre-production sample I got yesterday.
All I can say is wow. I have +/- 13 pitch and 10 degree cyclic. I can bog the 600MX easily when push the full throttle stick all the way up at a pitch pump. The KDE motor handles it really nice. The down side is my Voltz 3700 mAh 35C cannot keep up with it. The voltage alarm (set at 40.8v = 3.4v per cell) was triggered very easily. The Pulse 3700 mAh 65C can keep up the demand most of the time.
Be prepared boys and girls, this motor needs a decent battery packs to show its full potential.
HD750, TDR II, 2xTDR, Logo 700 XXtreme, Logo 550SX V2, Trioblin 700Comp w/KDE upgrades. KDE motors on all helis
taoY is offline        Reply With Quote
Old 03-04-2012, 04:50 PM   #7
NRPY
Are you using the SK gov, the ESC gov, or fixed endpoints?
Old 03-04-2012, 07:09 PM   #8
teshreve
Other than being a flying vibrator, my 600mx has great power. I also am using the Voltz 3700's. They are fading off earlier than I hoped. I take pretty good care of them. Probably won't be buying any more Voltz packs. They are sure light for their capacity, however.
Just ordered 2x 3800 Gens Ace packs. See how that goes...
Just pre-ordered the 600XF
teshreve is offline        Reply With Quote
Old 03-04-2012, 08:14 PM   #9
taoY
Running SK gov at 2350 idle 1. ESC is HW 70HV.
Old 03-04-2012, 11:09 PM   #10
NRPY
Still bogged with the proactive gov? Hmmm.
Anyway, hopefully the new GensAce packs will be the shiz. Otherwise, it's big $$$ for TP packs.
Old 03-05-2012, 01:52 AM   #11
zeeflyboy
What ESC are you using? If its a castle can you take a look at the logs and see the spikes? Interested in what the max current draw is...
Edit - sorry just saw you are using an HW... Nevermind!
Old 03-05-2012, 11:08 PM   #12
taoY
When running it on my 550 with 553mm blades, the max current draw was around 95A and average around 25A. The voltage alarm did not triggered with 2 x Zippy 40C 2650mAh. The current draw on 600 pro is higher because of the higher HS, 600mm blades, and heavier weight. Too bad I don't have a log. I am curious to know the current draw on a 600 pro too.
The previous post wasn't meant to scare you guys. Like everything else power related, you need to provide more energy on the input side to obtain more power at the output end. More powerful motor is harder on the ESC and battery. The Scorpion LE motors are one of the examples. As mentioned in my previous post, the motor works great on the Voltz 35C battery and works even better with Pulse 65C. I can't afford the TP 65C packs. I will look for some alternatives. Nano-tech has 65C packs, not sure how do those work.
What I really meant to say was you need a good battery packs if you are looking for serious power from this motor.
Old 11-27-2012, 07:36 PM   #13
isogloss3d
I just installed this motor in my Compass 6HV. I can't find recommended motor timing and see little mention of it anywhere. Still waiting for email reply from KDE customer support.
I'm currently running it with the stock HobbyWing 70A esc and may upgrade as needed. I was having problems with the stock Compass motor after 150 flights and the KDE was intended more as a replacement than a power upgrade. I'm mostly hoping for better durability and efficiency with less vibration.
I put in a couple flights at the default ESC timing of 15 deg and the motor came down very warm (much warmer than the stock motor). ESC temps were reasonable and unchanged from stock motor.
I didn't have enough time for more trial and error with different timing. Any input appreciated.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote
Old 12-06-2012, 07:31 PM   #14
isogloss3d
Default Motor timing for Non-Castle ESCs
I heard back from KDE Direct by email in a timely manner. Here's is what the email recommended for motor timing.
"The recommended timing for the Castle Creations controllers is Low (0), which produces a dynamic timing in the range of 5-8 degrees. Based on the Hobbywing manual, try 7.5 degrees initially and then you can increase this up to 15 degrees depending on your liking."
- Eric
Old 02-02-2013, 08:23 PM   #15
kiwianaBrad
whats the max amp draw on this motor
Yes I miss the odd screw, so what
Trex 700N Vbar, Mikado LOGO 600SX, Trex 450 SportV2, Trex 250se-dfc, MCPX ...DX8...
kiwianaBrad is offline        Reply With Quote
Old 02-02-2013, 08:55 PM   #16
isogloss3d
Well, KDE's specs state max power at 7,500 Watts.
Divided that by 45.6 Volts and you get 164 Amps.
My Compass 6HV runs 615mm blades but is closer in weight/size to an Align 550. I also don't run crazy pitch or HS so I'm hoping I can get away with the Castle 80HV.
- Eric
