Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 03-01-2012, 02:56 PM   #1
audio131
Default not happy..about a few things
ok so i picked up the kit today.. canopy looked at first glance.then noticed it was not fiberglass.. and at the slight bend trying to figure out wht is is IT CRACKED..ITS PLASTIC!!! where these days for a 500 $ kit to you get a plastic canopy??? terrible..............THEN ON all the pictures i saw and EVEN on the box it shows METAL bearing blocks...started the build..PLASTIC BEARING BLOCKS...really??? plastic.. i cant believe it,just cant..... the slop they will develop on a 12s heli beating on it will suck,, ..wondering what else im gonna hate about it.. ill let u guys know...
audio131 is offline        Reply With Quote
Old 03-01-2012, 02:59 PM   #2
audio131
Default pictured on the box and most seb sites
this is what is pictured on the box and it is pictured on most web sites
Old 03-01-2012, 03:00 PM   #3
audio131
Default and this is what is in the kit
and this is what comes in the kit!
Old 03-01-2012, 06:38 PM   #4
audio131
Default x50e
well the head is awesome, the tail assembly is maybe the best ive seen,, and the airframe is very light....still mad about the bearing blocks...
Old 03-01-2012, 10:18 PM   #5
DethWshBkr
Seems like it depends on what web site you look. Most sites have a plastic shown, and Tower Hobbies also shows a plastic. Thunder Tiger's site shows metal, but under optional parts, shows the metal parts in there.
What do you mean a plastic canopy?
Is it a thicker ABS, or a cheap thin lexan? Or is it thin fiberglass?
Blade SR; Blade 450 3D; Blade MCP x; Thunder Tiger X50(TT)
Sig Somethin' Extra, Seagull MXS-R with 22cc gas engine!
DethWshBkr is offline        Reply With Quote
Old 03-02-2012, 04:41 AM   #6
KouDy
Well i know it's not what you would like to hear but you can easily fix the plastic bearing blocks :
upper and lower
I know i know it's not in the kit, but still easy to fix (they are not that expensive) if you really want them.
There is incident described in X50 nitro section here where according to Hector, faulty bearing block caused his crash.
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 03-02-2012, 08:08 AM   #7
audio131
Default x50e
right on the box the kit came in has pictures of the heli close up with METAL bearing blocks............ the canopy is like a hard poly something. do not try to bend it. i bent it half of what i do most fiberglass one and like it said it cracked..
Old 03-02-2012, 08:34 AM   #8
gwright
The canopy is fiberglass, not plastic. I don't know what to say about the bearing blocks. The plastic ones seemed to be fine on the prototype I've been flying since septemble , the only time I've seen one break is after screwing up aerobatics in an auto, and watching it fall from about 100 feet with blades stopped, landing on it's head. That's about like hitting the head with a sledgehammer at full force, so I don't think anyone would expect it to stay together <G>.
gwright is offline        Reply With Quote
Old 03-02-2012, 05:00 PM   #9
audio131
Default canopy
no its a poly something of a plastic. i can slice it with a razor knife.,,the plastic bearing blocks will develop slop in short time with hard flights.
Old 03-03-2012, 03:25 PM   #10
audio131
Default bearing blocks
on the table have not even flown it yet ,i can grab the head and make the bearing in the upper block to move back and forth..the bearings just slipped in the blocks with no force at all..so nothing really wrong with plastic bearing blocks??
Old 03-05-2012, 07:14 AM   #11
gwright
That's really strange. I have three canopies for it and they are all fiberglass, including the new production green one. I'm absolutely positive due to the dust when dremeling. The motor I'm using is a few mm longer than thunder tiger intended, so I have to cut the top of the canopy to clear, hence the fiberglass dust. It's also obvious due to the fiberglass weave you see on the unpainted inside.
Old 03-05-2012, 06:27 PM   #12
ranma103
Hmm i'll let you know what mine is like when it turns up it's not far off now i've got all my stuff together for it can't wait for maiden flight but i'll need to do a nice slow build so i don't miss anything with it.
Cheers Luke.
Gaui NX4 FBL (SK-540)
Gaui X4 II FBL (Gaui Mini V 5.3 Pro)
TT X50 N FBL (GT5)
T-Rex 700N FBL OS GT15 HZ (SK-540)
ranma103 is offline        Reply With Quote
Old 03-06-2012, 10:40 PM   #13
bluepilot2003
I received my kit recently. My canopy is plastic. I will be installing the metal bearing blocks when I build it.
bluepilot2003 is offline        Reply With Quote
Old 03-07-2012, 07:19 AM   #14
audio131
Default x50e
i would definatly install the metal blocks. i can wiggle the bearing in the plastic ones(only highend kit on the market that comes with plastic bearing blocks ) does align still make a kit with plastic ones?i belive it was great planes idea to greater profit to have tt put them in the usa kits.. just my opinion
Old 03-07-2012, 07:23 AM   #15
audio131
Default canopy
yes if u go to towerhobbies it says "Canopy: ABS preprinted color shifting" . i think usa heli flyers sorta got screwed a bit with cheaper stuff in the kit for the same price.
Old 03-07-2012, 07:27 AM   #16
audio131
Default blocks
bluepilot. where did u order the metal bearing blocks from?
Old 03-07-2012, 07:31 AM   #17
audio131
Default blocks
never mind found them, pv1406 pv1407 .tower has them,
Old 03-07-2012, 09:17 AM   #18
gwright
Interesting. Guess I was wrong. Sorry about that. X series has only had fiberglass canopies till now , so this must be something new for the E version.
Old 03-07-2012, 09:34 AM   #19
gwright
Just got word it is something new. The nitro kits are fiberglass and the E is plastic. Really sorry about insisting they're all fiberglass,.. the plastic is something new and with my machine being a prototype, I only have f/glass canopies and that's all that has been listed till now so I was not aware of it.
Old 03-07-2012, 04:14 PM   #20
audio131
Default canopy
are the nitro canopys the same shape and size to fit on the x50e?? in case something happens and the stock one breaks.id go with one of those if they fit..
