Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 255
Hurricane 255 Discussion and support of the Gaui Hurricane 255
Old 03-02-2012, 01:39 AM   #1
ifly_65
Default Brass spacer question
The brass spacer that supports the tail shaft, which sits in the tail box is loose and is sliding down the tail shaft providing no support.
What should I do to keep this in its spot in the tail box?
Outrage Fusion 50 Gaui X5,NX4,X2 NX4: Savox sh1250, sh 1257, Ikon, Hatori pipe, OS 37 X5: RJX 0521HV X2:MKS DS 95l Spektrum H3020 7200bx Scorpion HSC MCP X BL NCcraig Flashed TA 915 9t.
DarkMatterBlades.com
ifly_65 is offline        Reply With Quote
Old 03-02-2012, 01:38 PM   #2
GravityJunkie
My bird has this same issue. Hopefully someone will chime in.
GravityJunkie is offline        Reply With Quote
Old 03-02-2012, 02:54 PM   #3
dpelletier
Green loctite?
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote
Old 03-02-2012, 03:05 PM   #4
ifly_65
I used a tiny bit of JB weld on the tail shaft and brass spacer. I was careful not to get any on the tail box so the brass can spin. I then removed as much as possible with a toothpick so the tail slider move all the way to the end at the tail box.
Old 03-03-2012, 11:41 AM   #5
GravityJunkie
Come on guys. Any more input into this. Is this normal? If not, how is yours held in place. I really don't want to be gluing things up. Mine slides on the shaft. It does seem to have an issue with binding the tail, but it doesn't seem to be a good thing sliding around.
