Old 03-02-2012, 11:12 AM   #1
NEAGRON
Default Bad Vibration
Hi All,as stated ive A really bad vibration on the tail fin,ive changhed amost every thing,any idea's please,could it be the main blades badly ballanced,please help,yours,Marty.
NEAGRON is offline        Reply With Quote
Old 03-02-2012, 12:01 PM   #2
egaus
Marty,
More info please.. When did this start occurring? After a crash? It could be a lot of things. Did you balance your tail assembly?
e
Logo 6003D Mini VBar 5.2 12s \ Kontronik Jive 80HV \ Xera 470Kv \ 623mm
Mini Protos µBeast 3.x 6s \ Yge 60 \ Stretch 350mm
egaus is offline        Reply With Quote
Old 03-02-2012, 12:26 PM   #3
NEAGRON
Hi Egaus,yes I rebuilt it after a crash it came done basicly on its head and slightly to the right,the only real visible faults where both sevo frames broke,blades spindle main shaft bent,there was ne damage to see at the tail,main frames where not broken,many thank's,Marty.
Old 03-02-2012, 01:01 PM   #4
Long Nguyen
Check 2 things: tail shaft and motor shaft.
If you have a vbar pro firmware, a vibration analysis will definitely point out what is the cause.
Long Nguyen
Long Nguyen is offline        Reply With Quote
Old 03-02-2012, 01:02 PM   #5
SMJT
Have you check the belt for any damage also the gears and the bearing in the tail?
SMJT is offline        Reply With Quote
Old 03-02-2012, 11:11 PM   #6
ziper_it
You said both servo frame were broken, what about the third lower support?
ziper_it is offline        Reply With Quote
Old 03-03-2012, 06:12 AM   #7
NEAGRON
Problem solved appears to have been bad Align 325 G bades,very rare for this to happen,yours,Marty.
Old 03-03-2012, 03:09 PM   #8
spykez
Hmmm... I was just thinking. Were they really out of whack balance wise?
I thought they were extremely good value. You see, I absolutely hate balancing blades, must be some mental block on my part. So I've not really gone out to buy really really cheap sub-$10 blades.
On the 2 pairs of Align 325 3G's I have found the CG's pretty much spot on, just needed 1 tiny piece of sellotape on the lighter blade and good to go. They're great, only about $18 here. Well worth the lack of hassle. They're currently mounted on my B450 FBL.
I haven't trashed my stock SABs on my mini P. These were essentially spot on so no sticky tape.
Prôtos mini's - trying desperately not to hit the ground...
spykez is online now        Reply With Quote
Old 03-04-2012, 03:03 AM   #9
NEAGRON
I tkink I mixed up to sets of blades,yours,Marty.
Just checked I put a 3G blade on with a F blade im a plonker of first class honors.
