Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 03-02-2012, 03:14 PM   #1
Relisys190
Default Aluminum Blade grips problem
Ordered a set of aluminum blade grips along with some 80degree dampers after a crash bent my feathering shaft on my 4503d, Get everything back together and noticed while installing factory wood blades that they do not fit! The black plastic (spacer) on the wood blades will not allow enough clearance on the aluminum blade grips. Is it safe to remove the black plastic spacer? or sanding it is also a possibility.
Thanks for the input, Markus
Relisys190 is offline        Reply With Quote
Old 03-02-2012, 03:47 PM   #2
2cants
+1, same problem. The carbon fibre blades still need shims too - so whats up?
Logo 600SE , Blade 450X *2, SR120, mCPx (HP05s & 120SR tail CF frame + bling), DX6i & DX7s and a Sh!t load of spares
2cants is offline        Reply With Quote
Old 03-03-2012, 12:02 AM   #3
Thalios
Do not take that plastic out. It would weaken the blades.
The alu grips are designed for smaller blade thickness like the carbon blades or the EXI FG blades
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is online now        Reply With Quote
Old 03-05-2012, 11:49 PM   #4
2cants
Would never think of taking the plastic on the blades out.
Problem is... the alloy grips are very tight on the wooodies & still require shims for CF, so they have changed the spacing with no real benefit except.
Old 03-06-2012, 01:39 PM   #5
Relisys190
Well i went ahead and ordered a set of align 325D blades. They are signifigantly lighter then the stock woodies for the blade 450 and im sure they wont have a problem fitting into the grips. I'll let everyone know how they fly. anyone have any input about the align 325D carbon blades? I got mine from Amainhobbies for about 19$. which is way cheaper then the carbon ones from Blade at 33$
Old 06-17-2012, 06:45 PM   #6
Rimon
I placed my wood blades in hard and they got in but they are very tight . but they are starting to loosen up by the time they are used. don't have a real problem with it
Rimon is offline        Reply With Quote
