In the boom on the torque tube?? what are you guys using? I am starting the slow rebuild and I have an extra bearing, does this actually help with vibs at all?
USMC - EXPEDITIONARY AIRFIELDS - MCAS MIRAMAR To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Align Trex 500 Scorpion 3226-1400 powered missile |
I use two...
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
did you guys notice any differences with having 2 bearings?
One
Always have, in the specified spot Never a vibe issue, never failed. Every vibe issue I have tracked down has never been solved by adding another bearing to the TT
Dave Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire |
#6 |
#7 |
Of the 3 TT shafts I've purchased since converting, not one has been very straight. And for the money, I'm not going to do the "Roll it on a flat surface to straighten it out" technique.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760 DX8 |
#8 |
Tail belt is the way to go, you will never look back and spend money again
#9 |
I have never seen a bent TT , new in packet
#10 |
I just never check. I like to assume its straight
#11 |
even if it is bent, 2 bearings can't fix that
#12 |
same here.
Team HeliDirect Skookum Support Flying Align, controlled by Skookum, and powered by Pulse |
#13 |
Since I was curious, and my 500 Pro is equipped with an SK-720, I tested the "two TT bearings reduces vibes" theory. The attached screenshots are from the SK-720's vibration spectrum analyzer. The big peak in each plot corresponds to the tail rotor RPM, which is where tail vibes show up.
Bottom line: no significant difference in tail vibes with an additional TT bearing. In fact, two TT bearings resulted in slightly higher vibes, but the results are close enough such the difference can be ignored. |
#14 |
I had a strange noise a few months back so I added another bearing but it did not help (turned out at the end it was old Boca beraings in the motor). I did not take it out but I don't think there's a significant advantage. I never had a bent torque tube, always checked when pulled a new one from the package.
As for the belt, it was the part that cost me the highest repair cost ever when broke so I ditched the belt setup and never looked back. YMMV.
I am a HeliCoholic! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Fusion50FBL μBeast TRex500FBL μBeast Blade 130X Blade Nano Spektrum DX8 Blade 120SR handbuilt Coastguard AW109 see my avatar For the winter:Reflex XTR
