Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 03-22-2012, 12:14 PM   #21
newhelicrasher
Originally Posted by bunick View Post
Will the the tail boom from a MSRx work? I haven't figured out what size the MSRx is. I know the 120sr is 3mm I believe.
http://www.ebay.com/itm/BLADE-BLH320...ht_3221wt_1059
The tail boom on the msrx is 2mm. Also just to inform you the tail boom that is stock on the msrx is not even adequate for it. Most Msrx owners consider the mcpx tail boom to be a necc mod to get these to even fly right. The msrx boon is shorter by about an inch..extending it with the mcpx boom moves the motor out of main blade wash out plus being further out the tail motor does not have to work as hard.
All.that being said the 120sr is much bigger and although I dont own one my guess is the mcpx tail boom even if upgraded to a3mm aftermarket version would still be much too short for the 3x bigger 120sr.
Also note the stock 120sr boom is a good mod to add.to the mcpx...as it has the same effect as the above mod on the msrx. It would make more sense to me to find a longer boom for the 120 rather than a shorter which the mcpx surely is.
Blade ScoutCx/MCX2/MSRX/120sr/DX6i
newhelicrasher is offline        Reply With Quote
Old 03-23-2012, 05:42 AM   #22
Harmwalker
How did you mount it? Any pics?
Harm
120SR - 130X - nCPX
Lovin' this hobby!
Harmwalker is offline        Reply With Quote
Old 03-23-2012, 05:47 AM   #23
Harmwalker
Originally Posted by sucmanhtritue View Post
I do upload a picture to show mSRx main motor compared with 120 tail motor (without the plastic cap, but i do measure them from the metal part). The mSRx main motor is about 3mm longer than the 120 tail motor. Sorry if the picture is too big
I also use 1200 mAh battery (as its labeled), weight about 2 times stock battery, fly time is about 8~9 min. After a flight both motors get a little bit warm (if i hover, cool->normal if i fly around (both are indoor))
I do not own mQx, but i also think that these motors from mQx are the same as mSRx main motor.
link to bigger img: _http://i.imgur.com/TRKIJ.jpg
How did you mount this motoer? Any pics?
Harm
120SR - 130X - nCPX
Lovin' this hobby!
Old 03-23-2012, 08:43 AM   #24
Oh no... not again!
Just get some 3MM carbon rod and make your own booms. You will nee the RK Tail motor mount and strip the wire out of a stock tail boom.
Much cheaper in the long run!
Oh no...
Oh no... not again! is offline        Reply With Quote
Old 03-26-2012, 08:22 AM   #25
sucmanhtritue
You just put it in. It has same size as the default, only the length of motor is different (as showed in pic)
sucmanhtritue is offline        Reply With Quote
Old 03-26-2012, 12:50 PM   #26
Harmwalker
Oh thanks! The pic looked like the motor on the left was had a larger diameter...
Harm
120SR - 130X - nCPX
Lovin' this hobby!
Old 03-26-2012, 03:59 PM   #27
Heli-cat
I thought the same...must just be an illusion
Heli-cat is offline        Reply With Quote
Old 03-30-2012, 04:32 PM   #28
Harmwalker
Anyone know what the weight difference is?
Harm
120SR - 130X - nCPX
Lovin' this hobby!
Old 04-06-2012, 09:34 PM   #29
Heli Wheels
I just got mine, I didn't resolder though, I just plugged it in backwards, but I'm lazy.
I don't mean to offend, this comes quite naturally.
Heli Wheels is offline        Reply With Quote
Old 04-28-2012, 03:12 AM   #30
jamesandyori
Darn it. I did this msrx main motor and I still have the wag! I even soldered to the board.
Tomorrow I'll try a extended boom!
James
DX6i / Brushless MCPX / 2 stock MCPX / MQX / 120SR / Scout
jamesandyori is offline        Reply With Quote
Old 04-28-2012, 04:22 AM   #31
stonednbroke
Still not been able to get my hands on a motor, let us know how that extended boom goes bud
stonednbroke is offline        Reply With Quote
Old 04-28-2012, 11:45 PM   #32
jamesandyori
I tried a lot of lengths today and I feel that 8 inches is the best, but I still have tail wag!
I put the motor back into the msrx, I will just use the new stock tail motor I feel there was no big difference between the two motors.
James
Old 04-29-2012, 08:06 PM   #33
bunick
I replaced mine with one and can't tell much difference. But the price is the same and it looks like it ought to be beefer with longer wires to work with. If you break a wire on the original tail motor it's like trying to solder hair.
bunick is offline        Reply With Quote
