| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Took my brand new 550 out for what I consider its 3 or 4th maiden ( never really got off of the ground yet due to various reasons that I posted about with servo arms and stripped gears).
I had just put the canopy on and I heard a pop and saw a flash. I disconnected the battery immediately and saw smoke coming from the BEC's area. The wires feeding the BEC must have short-circuited or overloaded as they melted in the middle of the run of 16 gauge wire that feeds the BEC from the battery. The wires that go back to the Skookum powerbus seem to be a little stiff, like they burnt a bit. I am only hoping that my servos and SK-720 didn't fry, because if they did, I am done with all of this ![]() Any ideas on the cause and if I should contact Castle for a replacement? Since I will probably need to order a new BEC for the short-term, and I already have a CC ICE 100, any suggestions on a replacement? Stick with Castle Pro or is that crazy? Thanks! -GN
Whiplash 90N | Goblin 500 | Gaui NX4 | T-REX 600E PRO DFC | T-REX 550E V2 | Blade 450X | Blade 130X | MCPX BL | DX8 | BeastX | MSH Brain/Ikon | SK720 |
#2 | |
Did your wires get caught between the canopy and the CF frame? When I look at the pics it almost looks like they were pinched and shorted....
Let me know Quote:
I guess that is possible as I just finished putting the canopy on. I stuck the loose wires inside of the canopy and put it on - it didn't feel like there is much resistance while attaching it. I will inspect it closer tonight. thanks for the input.
Looks like the carbon base plate wore through the wire insulation. You can see where the electrical short took place from the missing carbon, exploding black soot residue. Both the red and wires seem to be burned through at the same locations, too.
I'd call this one a direct short due to the carbon base plate. No fault to the bec from what I see. Have you determined if the bec is ruined or did it just puff the plastic and carbon during the short? Hope you make out ok. |
+1 on the canopy. that canopy clip locks pretty quickly when it finally locks and i know my stock canopy overlaps the carbon so much it notches the fiberglass so if they got between it i could def see it cutting through, not much too that wire or covering.
Trex 450pro FBL Mini V Bar, YGE 60, scorpion 2221-8 Trex 550V2 FBL V Bar, YGE 100, kde 600xf-1100 mCPx 2 Trex 700e dfc hv V Bar silver line, CC Ice2 120hv |
#6 |
You need to zip tie the wires out of the way not against any sharp edges. They shouldn't be so loose you need to tuck them in to the canopy.
Rich Trex 500ESP FBL BeastX Synergy E5 VBar Synergy E7 VBar |
#7 |
i would think the BEC is fine, repair the wires and power it up again and check the output.
As mentioned and from what I saw in your pix the wires shorted on the CF frame, should be no damage to the electronics, not sure about your pack though
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
#8 |
+1 on wires shorting while putting your canopy on.
#9 |
Yep the second pic says it all.
Align 450Pro 3GX, Align 500 3G Align 550 3g, Velocity 50 Vbar |
#10 |
Thanks for all the input. I have just finished my repairs and everything looks to be in order. I hooked it up to the Castle Link and didn't see any errors. The SK-720 looks to be functional. I connected my battery up to the charger and the voltage seems correct and the cells all seem to be present and balanced - I am a bit paranoid about electric and fires, so is there anything else I should do to make sure that the battery is safe?
I am going to go over everything once more and make sure that the wires are all secure. I still went ahead and ordered a new Western Robotics Hercules Super HBEC Mini G2 just in case ( the LHS and the few online stores that I order from were out of the CC BEC Pro anyways ... even though it looks like I was actually the one to blame The weather looks to be really nice tomorrow - 60 degrees, so I hope to get this thing off of the ground and back down safely at some point in my life! Thanks again, GN
#11 |
Looks like a sensible conclusion would tend to agree about the canopy and wires, must say I played around wih mine until I could get the canopy on without a lot of faffing about and took great care with the cable runs.
Got to respect these power systems guys, with a 30C battery You have over 3.5kw available, the average electric fire element is 800watts to 1kw, the battery can supply the equivelent of a 3-4 bar electric fire for quite a few mins! Enough to cause a raging electrical fire. Scary stuff.
TREX 550E LOGO 500SE & 600SE & 600SX Synergy E7 zzzzzzzzzzzzzzTDR |
#12 |
Another lesson is that carbon fiber can conduct electricity - I didn't really think much about that fact when building, was more concerned with just damaging the wires on contact with a sharp edge.
Maybe plastic frames have a slight advantage since there is so much power involved and the multiple wires contacting the frame? -GN
#13 | |
#14 |
your BEC is probably fine, just repair the wires and re-route them away from that area, out the side perhaps
