| Atom 7HV Compass Atom 7HV Model Helicopter Discussion |
i just noticed this today with the blades off. was checking for vibrations on the vbar. and i notice i had alot more than i did when i first setup the helicopter. i tried my best to record the sound....but its not very loud...well it is on mine since i have good speakers....but..here is the video for whoever can make out the sound
Compass 7hv - Fusion 50 - Trex 550 Stretched |
Did you lube the belt and the idler bearings?
My Atom developed a similar squeak-it was the dry belt rubbing the flanges on the idler pulleys.
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
i did before i first flew it =\. only flown it 4 times. i can lube them again and see. is that also the clicking noise? if you can hear it
I could hear the clicking, but could not identify the source-my apologies.
Make sure all the bearings are lubed, for the squeaking issue.
i also have one more quick question. how do i prevent my flight pack wires from getting cut on the frame? this happened twice already. first time i heat shrinked it. second time i plug up and see smoke and unplugged it fast...pulled out the battery tray..and its cut again. im trying my best to be careful when loading and unloading...but i just dont know
#6 | |
Copter X Hybrid Beast X Trex 500 Vbar ,Trex 600 ESP 12S Vbar Compass 7HV Mini V Compass 6HV Vbar To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
meh no i did not sand them =\ i forgot about that honestly lol...ive never done it before on my other helis =\ guess ill do that and see if that works, didnt think it was that sharp
#8 |
Mine had the klicking noise develop too! its something to do with the one way bearing. I found that if I pulled the tail pully gear away from the main gear on one side it would go away. I took the hole gear assembly apart but I couldnt find any obvious issue so I put it back together again and the click was gone! I think it had something to do with the lateral load from the belt. If I took the belt off there was no click!
6hv (fb) 7hv DX8 |
#9 |
thanks a lot guys! quick responses. will check this thing out now
#10 |
well i took out the main gear/auto gear...and the noise is coming from these gears when i spin em by hand i still hear the squeak and the clicking
edit: ok. i cleaned out the one way bearing. (was really oily and black stuff all in it) and put in some grease. and closed it back up...squeak is now gone. i still get a click noise, but not as bad as before. i did notice i can get one of the bearings in the hub to click but turning it back and forth over and over and ill hear it every once in a while...but it feels pretty smooth...maybe i need to replace that bearing
#11 | |
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
#12 |
thanks, do you have a link to the tubing that you used? thats a good idea.
i still have the clicking noise even with the main gear assembly out of the helicopter. the squeak is still gone....but..click...i have no idea
#13 |
Check each bearing individually.
#14 |
Formerly BarnStormer
Link please!
"You can still call me Barn To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. " Team Compass USA ProStarHobby.com Scorpion Power Systems |
#15 |
I think it's called haye's, black obviously. Works great, I use it too sine I have no more nitros.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD |
#16 |
I just noticed on the click noise? On mine I can hold the main gear with my hand then grab the head and move it back and forth I noticed a slight gap in the bolt that holds the main gear to the main shaft? I mean the main gear moves side to side on the main shaft. Like the bolt holding the main gear is to small in diamiter is this normal with the 7hv? Or could I have gotton my main shaft upside down? I was thinking this could be the click your hearing??
"Quit crying about your airplane and fly it already!" |
#17 |
mine doesnt seem to have any play like that
#18 |
Thank you for the reply, I will be looking in to my problem. I have not maiden it yet maybe this is why I hear of people shearing of their lower Jesus bolt?
#19 |
There is play on the bolt through the main shaft if there isn't a tiny bit, something is wrong. You should not crank down on that bolt of or the grub screws that go into the OWB as it will warp the assembly a bit making OWB failure or wear more likely. I found that the squeak on mine was coming from the tail older pulley on the tail case You don't want the idler touching the belt as it can wear prematurely and start to squeak.
Atlanta RC Club, The only club inside the city. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep. |
