Old 03-01-2012, 07:31 PM   #1
Wesley888
Default Woot! Got my Align 450 Pro v2 3Gx Kit
The UPS guy can't hide from me today! The box is much smaller than I expected. Let's the fun begin.
Align 450 with NAZA-H, 450XL, XCell60, Align 700e, Skookum SK 720, SK-GPS, DX8. ArduPilot (APM 2). Talon 625 Hexa with NAZA-M.
Wesley888 is offline        Reply With Quote
Old 03-01-2012, 07:38 PM   #2
BLAZE86DUBZ
good luck i just finished mine last week flies great got rid of the 3gx though went with the beast x maiden flight went flawless
BLAZE86DUBZ is offline        Reply With Quote
Old 03-01-2012, 08:31 PM   #3
crf69
i was very surprised how small the box was too.
this thing is fun to build im still in the process.(a long drawn out taking my time process)
My first real kit.
Buy good stuff then you never have to apologize to yourself for being an idiot....
Stay Inverted My Friends. Ryan Robinson 7hvGob7GauiX5Warp360SYNE5
"How high does it go?" Love that question.....
crf69 is online now        Reply With Quote
Old 03-01-2012, 08:34 PM   #4
Wesley888
Thanks. I'm going to sell my 3Gx as well. Just going to put a SK720 in it.
More pictures...
And all of the screws are not Loctited. The bearings are not greased at all.
Old 03-01-2012, 11:29 PM   #5
Viet-Lama
Man thats sweet! Congrats!
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 03-01-2012, 11:38 PM   #6
dominoedge
Congrats. Looks like you got sucked in as quickly as I did. I'm on my 4th heli now in less than a month's time. However, I couldn't find a 450 Pro 3GX in stock anywhere so I went with a 550 one. Just got it, about to start building.
dominoedge is offline        Reply With Quote
Old 03-01-2012, 11:51 PM   #7
Wesley888
Thanks. I almost went with a 550 as well, but I figure 450 would be much cheaper to fix since I'm so new at this. I'm sure I'll move up again when I'm done with the 450.
And by following Finless Bob's video, I just got the frame done and got my TX configured for the 3 servos.
Old 03-02-2012, 05:53 AM   #8
Wesley888
Using zip tie method and re-adjusted all 5 links. Got the swash plate leveled and the blade pitch corrected. That's all for the day.
Old 03-02-2012, 10:27 AM   #9
-kenny-
Wow that takes me back My girlfriend and friends couldn't believe that a 450 was going to come out of that tiny box. These are real nice heli's to build. The building almost becomes an addicition. I got my 450 in octobre, built it, had sooo much fun i couldn't stop dreaming of building another one. Started thinking about a 550 and couldn't resist. Got one in january. And i'm allready thinking of wich one to build next
Have fun!
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote
Old 03-02-2012, 11:16 AM   #10
distructor
Subscribed. The T450 + SK720 are what I had selected for my next build as well. Please keep us updated.
Takeoff is optional, landing is mandatory.
Blade MSR, MSRx, MCPX*4, B450x+HC3SX, Protos 500 stretched+Brain, Century E640+HC3SX
distructor is offline        Reply With Quote
Old 03-02-2012, 11:17 AM   #11
Wesley888
Have fun!
I can imagine. I really enjoy building it as well. I spent extra sweet time to sand down all of the edges using quite a few different shape and sizes of sanding tool, but by hand. Treating it like a piece of art. I don't think I've ever done that.
Will do.
Old 03-02-2012, 04:58 PM   #12
Wesley888
Hmm... i don't see the instruction on installing the rudder servo. This is Trex 450 Pro V2. Quite a bit of the set up don't match what Finless Bob's video. Just want to make sure I still use the closest hole in that servo.
EDIT: nvm. It is binding on both side so it certainly needs the least travel. Even using the closest hole, I still have to set the travel limit to about 50% for the rudder control.
Old 03-03-2012, 01:21 AM   #13
-kenny-
It should be in the manual somewhere. If you like, i'll check it for you. Never mind if it's binding now, completely normal, and DON'T adjust travel in your tx. The limits are set when you do the rudder gyro setup.
Old 03-03-2012, 03:13 AM   #14
Wesley888
Finally found the page. It was way at the end.
I just finished putting it all together and finished doing the wiring as well. Almost everything and wires are inside the frame. Quite clean.
When I start doing the SK720 setup, I then noticed that all the calibrations, reverse, sub-trim, swash mix, etc are not needed. SK720 requires everything set up again from scratch.
One more thing, the SK720 does not come with any cable. I'm using a Spektrum receiver AR8000. It consist of 2 pieces, 1 to control, and the other one is a remote receiver. I need to have both of them connects to SK720. I don't have those tiny plug cables at home at all. Going to see if any local stores open tomorrow. If not, can't do anything until next week.
Old 03-03-2012, 03:47 AM   #15
-kenny-
That's right, i forgot you were using the skookum. Wow that sucks for such an expensive unit to come without any cables.
I would for sure set it up with the 3gx untill i got the cables for the skookum then again, i don't have much patience
Old 03-03-2012, 03:54 AM   #16
Wesley888
Yea, right? A $400 unit doesn't even come with the cables to connect to the receivers. I found it a bit outrageous.
Old 03-04-2012, 04:47 AM   #17
Wesley888
Found a local store that open 7 days a week and they have pretty much everything I can think of. Got my cable and power plugs. Got the SK720 configured just now. Going to have the maiden flight in the morning.
Old 03-04-2012, 10:47 AM   #18
rbader1
Good luck!
Align TREX 450 Pro V2 3GX
Align TREX 250 Pro 3GX
Blade 130X, mCP X BL, mCP X V2, mSR X, 120 SR, mSR, MCX2
DX8
rbader1 is offline        Reply With Quote
Old 03-07-2012, 09:01 PM   #19
Wesley888
The maiden flight went well, other than the landing was a little rough. I was flying it in the backyard and the ground was uneven. As soon as it landed, it striped the torque tube front gears.
Went to the local store and paid $13 for the set of gears. Changed it. It was very windy outside but I just couldn't wait. And few flights later, another striped gears! Very irritating.
Now I have a blob of sponge warped at the bottom of the tail fin. And a couple of rough landing tonight and no striped gears.
By the way, the basic tuning (Section 16 in the manual) of the SK720 is pretty much done. I'm in the process of the Advanced Tuning now. It involves trimming the swash for level hover, even if it means to make the swashplate not level. Very interesting.
While doing that, I just thought of using a self leveling laser to re-tune my swash level as a starting reference. It works much better than the zip tie method.
Old 03-07-2012, 09:04 PM   #20
michael88997
nice idea.. i would stock up on those gears cause you will strip them easy... shes a fine lady, dont be too rough with her
michael88997 is offline        Reply With Quote
