| Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion |
Im not to sure about my settings for this ESC. It has a few more options that Im use to and hoping someone can check my settings and see if they are acceptable for my setup.
1-8 1. Cut Off Voltage 1 Auto Lipo 2. Current Limiting 4 Insenstive 3. Brake 5 Disabled 4. Throttle Type 4 Governor Mode High 5. Timing 2 Standard Advance 6. Low Voltage Cuttoff Type 2 Soft 7. Soft Start 2 Soft Start 8. PWM Switching Rate 4 Outrunner Thanks for any advise |
I have a 2221-8, not -6, but here is my advice for what it is worth.
I use governor Set RPM - really easy and works very well. Just type in the speed you want - simple. I don't use Outrunner as I found the motor ran hot. I use 8kHz. Otherwise it looks OK, but I can't remember my timing - I think it was low. Depends how hard you want to fly and hot the motor gets. Colin
Vario Long Ranger 700e Seahawk 600 - work in progress Atom 500 Trex 450 SA hybrid |
