Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 01-10-2005, 11:29 PM   #1
RythmSekshun
Default Can you paint carbon fiber...
...successfully?
I want to paint my vertical 3d fin. Can I just roughen it up a bit, prime it, and then paint it like anything else?
Or do I need to go throught some insane process of preperation?
RythmSekshun is offline        Reply With Quote
Old 01-11-2005, 02:42 AM   #2
ChrisLaFollette
Hmm I was thinking about just that today when looking at mine. I bet if you roughened it up a bit then shot it, it should turn out alright!
ChrisLaFollette is offline        Reply With Quote
Old 01-11-2005, 04:45 AM   #3
sdixon747
I painted the fins on my Fury and they turned out fine. Just wet sand with some 320 then 400 sandpaper, prime then paint.
Steve
sdixon747 is offline        Reply With Quote
Old 01-11-2005, 08:59 AM   #4
ThBrtmn
It can be done...I have seen some of the Canopy painters do matching fins...I just dont know of the proper procedure.
"FREAK" Out
~Bart~
ThBrtmn is offline        Reply With Quote
Old 01-11-2005, 09:17 AM   #5
Heli_jack
no sweat, treat it like fiberglass
Heli_jack is offline        Reply With Quote
Old 01-11-2005, 10:51 PM   #6
megarckid
be sure to claen it real good with acetone or alcohol if you have had them on your heli they will soak up some fuel in the fibers
Synergy E5 6s stretched set up, Synergy N7 OS.91 speed with powerboost pipe on 30% cool power align 450, nano ncpx bl, mcpx bl, blade 450,
megarckid is offline        Reply With Quote
Old 01-13-2005, 04:20 PM   #7
Mike Fortin
I might as well give this a shot as well!
Mike Fortin is offline        Reply With Quote
