| Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only |
Exi 450 se2 v2 (ready to go just need rx/tx). Carbon fiber frame, metal blocks. T-pro mg90 cyclic servos, Exi D213p tail servo, Turnigy H2218-3200kv motor, Exceed Proton 30a speed control. Lots of extras. I only hovered it a few times. Heli's just aren't for me. Wish I had the time to learn. No TX/RX included. Upgrade screws (rc screwz)
KDS Flymentor installed (have box and programming cable) 3 sets pro 3d cf 335mm blades 2 complete spare rotor heads (one brand new(exi), one needs work(think it needs bearings) both metal 2 spare drive belts Hs1139t upgrade set hs1208t Tail rotor blades Gy48v Dectrum gyro (used when flymentor is removed) HS180t Main shafts (3) hs1264t flybar (2) exi flybar Hs1219t-84 main gears Hs1220t-84 drive gears Hs030t tail booms (2) Exi tail rotor (new, metal, w/drive belt) Exceed Carbon fiber flybar weights 66p84 H45100t tail rotor shafts Hs1251t feathering shafts Exi metal tail rotor parts T-pro sg90 servos (3) 2 Sky lipo 3s 20c 2200mah lipos Paypal only $500 Would like to keep shipping to US only. Sold as is no warranty. Helis is in good working order. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by mcdader; 03-08-2012 at 10:33 AM.. |
Just so you know this is not a 450 pro
its actually a se2 v2 clone the exi 450pro clone would look like this one http://www.xheli.com/18h20-exi450pro-shaft.html its a nice helicopter. I have a exi 450pro it is every bit as good as my trex 450 was
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
Thanks updated the description.
Any reasonable offers?
bump?
#6 |
Pm sent
Trex 250 Pro, Tarot 450 Pro FBL ZYX, Trex 500E FBL 3GX, Trex 550E FBL 3GX, Chaos 600 FBL Robird G31 |
#7 |
PM sent
RC Weight Loss Program. The more I buy, the less I eat. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
