Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 03-08-2012, 08:12 PM   #1
505b400
Default Noob questions on starting
I am planning on getting a turbine and have a few questions about the propane/ butane used for starting. My first question is, how long does a bottle/tank last? Roughly how many starts? Also where do you generally get the mixture of gases? Also what mix ratio? Thanks for your help, I swear I searched for an hour!!
Trex 500, Trex 450 pro
Bergen Intrepid mw54 TURBINE!
505b400 is offline        Reply With Quote
Old 03-08-2012, 09:33 PM   #2
Skiddz
You can get the propane/butane mix from sporting goods stores.
http://www.google.com/products/catal...ed=0CHEQ8wIwAg
You'll need a fill valve (it just snaps on top) and you'll need to hold the can upside down as you fill.
If you can still find it, the Colerman Powermax works great and lasts quite a while. (and you don't need to hold the can upside down)
I've had my turbine for almost 3 years and JUST started my 3rd can of Powermax. With the 5 cans I have on hand, I'm good for the next 5-6 years.
-Kevin
Skiddz is offline        Reply With Quote
Old 03-09-2012, 07:08 AM   #3
505b400
Thank you very much!! Is this the coleman powermax you were talking about?
http://www.google.com/m/products/cat...ed=0CEsQ8wIwAw
Old 03-09-2012, 08:59 AM   #4
cbergen
The fat, squat, green and blue can is what we currently use for starting gas. It is a 70/30 mix propane/butane and works perfect for this application. It DOES require to be turned upside down when filling the onboard tank.
I usually find it at Wal-mart for appx $5.00 and lasts for 20+ starts.
The Powermax that Skiddz is referring to is a taller, skinnier, Silver can, apparently no longer made, but they still show up on occasion. This can has a standpipe in it so does NOT require to be turned upside down.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote
Old 03-09-2012, 03:40 PM   #5
Skiddz
This is the Powermax fuel:
There are two fillers you can use for the fuel bottle/can:
This one from RC Gear:
http://www.rcgear.com/products/PowerCap/
or this one from SinCity Jets (I'm sure there's other places to get it as Sin City's price seems ridiculously high)
http://www.sincityjets.com/accessories/DSC00609.JPG
Schulman Aviation used to have it, but I don't see it on their website anymore..
-Kevin
Old 03-10-2012, 08:39 AM   #6
flyingrhino
Some of these things might be included in the sale of a used turbine heli.
Bergen Tazer 800, Bergen 44 Magnum, Trex 600E, Trex 600ESP, Trex 450SE
AMA 727477 Turbine Waiver RW2070
flyingrhino is offline        Reply With Quote
Old 03-11-2012, 07:09 PM   #7
cbdane
I have 11 hours run time (over 100 flights) on my Magnum 44 and I'm still on my first bottle of Powermax, which feels (from the sloshing) about 1/3 full. I only top up the propane tank every 2-3 visits to the field which corresponds to about 8-10 flights. I had no idea it would use so little so I'm feeling a little silly with 9 more bottles in the cupboard.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 03-11-2012, 11:04 PM   #8
cbergen
Seems like you used quite a bit that first day, though after we talked I guess it worked better.. Lol.
Chris D. Bergen
Old 03-12-2012, 12:28 PM   #9
cbdane
Yep, still that same bottle.
Old 03-13-2012, 05:30 PM   #10
1hander
get a kero or convert to kero start and forget about the gas, you wont regret it
Ret Dis SSG Gonzales
5th SFG
De Oppresso Liber
1hander is offline        Reply With Quote
Old 03-15-2012, 11:31 PM   #11
Skiddz
That's a viable solution IF your engine is capable of being converted. I'd love to do the conversion on my MW-54, but can't due to the combustion chamber setup...
I believe all the MW-44s available now can be converted to kero start.
-Kevin
