| mCP X Blade Micro CPx Helicopters Information and Help |
I've been practicing nose in hovering and noticed yesterday that expo was causing me to jab the rudder stick. I decided to turn off all expo in normal and stunt mode to experiment and found that for me a touchy heli is better. People seem to put a lot of emphasis on expo, so now I am curious. The thing is everytime I realize something like this, I end up stepping back in my progress to get used to the change. I know it's part of the learning process.
Who likes using expo and how does it benefit you? |
With FBL helis you don't use expo at all as the FBL unit does the expoing for you.
On a fb heli it is common to use some expo on cyclic. When it comes to rudder I think it is more common to set the expo to zero. This is however not a rule, it is a question about what you are comfortable with. Play around and experience for your self how your heli responds to different setups. Only then you can figure out what is best for you |
#3 | |
You learn by everything
When I got my mcpx it had been about 3 years since I had flown a heli. I used 40% expo on the Aile and Elev to start out to tame down the heli. I haven't touched the Rud expo. When I got used to the heli roughly a week of hovering and FF I started reducing the amount of expo. Now I'm flying with 10% expo.
I'm sure everyone is different in the way they approach setup, but this is what worked for me. |
#6 | |
#7 |
I love every last bit of response from user control whether it be steering response and throttle response on my race cars or cyclic response on my helis, but I like expo on my brushless birds. They dart away so fast I like to fly them with a little expo.
#8 |
Zero expo here too. At first when I got the MCPX I was using about 35% expo indoors and like 15% out. Then I tried it with 0 expo and never looked back.
#9 |
Thanks for the heads up. I have all the parts for a BL setup. I'm just trying to decide my battery setup before I actually do the mod. Going HPO5S for my first one. Definately keeping that aspect in mind. Makes sense.
#10 |
#11 |
On my brushed and lower power BL motors I did not like expo at all. On my current 915 I feel like 10% on Ail and Ele make it more controllable with over 7000 Rpm.
To me it's more for precision landing and tight quarters flying. Any sort of 3D and larger space flying I feel Expo hinders performance and actually makes it tougher to fly as you need more stick movement.
Tarot 450 Pro V2 DFC 6S - Scorpion 2010 - YEP 45A - Hitec 5065 - Hitec 5084 - Robird G31 Trex 500E DFC - Castle Vertigo 1800 - Castle ICE75 - DS510M - DS520 - AR7200BX MSH PRÔTOS - Scorpion 880 - YGE 60A - Futaba 9650 - Futaba 9254 - AR7200BX |
#12 |
For me as I've increased dual rates I also increased EXPO . Find what you like and dont worry about what everyone else is doing.
Team MicroHeli Team HeliProz Check out my Youtube channel JJ Inverted Production http://www.youtube.com/user/JJInvertedProduction?feature=mhee |
#13 |
High dual rate for tic-toc (attempt anyway) and some expo for precise landing in one flight same setting.
#14 |
I prefer a heli that responds crisply and don't like much expo at all.
If anything on my MCPX I like my rudder -5 or -10 otherwise the tail is not quick enough. |
#15 |
I use as less expo as possible too. Between 0 and 15 max. On the mcpx i have 0 on cyclic and even -30 on rudder. I don't like a soft response, less expo makes for a more precise hover aswell.
As far as not using expo on fbl heli's, it's more convenient if you disable all expo on the fbl unit so you can adjust expo on the fly in your tx
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6 |
#16 |
I always flew my Blade 400 with 0-5% expo, but I started using more since getting back into flying with the mcpx and my foamies. Maybe just because I'm still spooked by flying indoors...we'll see what happens once the weather breaks.
Blade 400 || mCPx || Trex 500 ESP 3GX learned basics in winter '09, started again in winter '11 after year or so hiatus currently working on: piro flips and inverted circuits |
#17 |
I use rudder -30% aileron and elevator -10%.
Makes it much more sensitive. I feel more connected to it without any lag. Bill |
#18 | |
Maybe yo were trying to make another point (trim?), but FBL does not have built in expo. FBL stablilizes the heli, expo adjusts how sensitive your sticks are around mid-point. |
#19 |
#20 |
Just keep in mind for all you folks with Spektrum or JR Tx, to add expo to a control, you must enter a positive number, not a negative number, to properly feel the effects of expo with your cyclic or rudder...Futaba Tx use a negative number, if I am correct...
Do You want to fight, or Surf? Goblin 500 DX8 T Rex 500 Trex450 Blade mCPX mCPXBL mQX |
