| 2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
I bound my setup and dx8 but when i power everything down and then on again my copter is not seeing the dx8.... Fast flashing satellite and rx no response to my radio? Have i bound incorrectly. Tm1000 to data/bind port of AR8000. Bind button pressed on telemetry while powering on hexacopter, then power on dx8 bind button pressed....
Sent from my GT-I9100M using Tapatalk |
im not 100% positive but i think you need to get the ar8000 talking to the tx first then add the tm1000 and rebind. give it a try until someone else with more knowledge jumps in
good luck man
EXI 500 DFC/3GX v3.1 ICE 75 Bec Pro Align trex 500DFC Pro w/ 3GX v3.1 DX8 V2.06 |
Thanks for the info, my ar8000 has been workin fine, bought the telemetry a month after so i had the rx talking originallly now the tm1000 got me buggered
Is it possible that the bind button on the TM1000 is stuck? That would cause this symptom.
John Compass Knight 600E, Blade 450, Blade 400, Blade SR, Blade mCPx, Blade 120, Blade mSR, Blade mCX, Blade CX2 |
Also try unplugging the sensors. I had a temp sensor that was shorting and causing the TM to go in to bind mode on every power-up.
I just unplugged all the sensors, power up and see if it's ok, then pluged them in one at a time, power cycled between each one to find the offender.
TRex 250 DFC | TRex 250 DFC (Scale) 2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale) TRex 550 DFC DX8 + Telemetery on all |
#6 |
Joe tried your advice, all i well when no output is plugged in, also now when i do plug in voltage and cycle power it works fine... I dunno what's changed but it has stayed bound throuhh 8 cycles. Thanks for the info
