Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 03-09-2012, 09:35 PM   #1
TheHeliDude
Default Blade SR charger - charge 450X batt?
So I have a Blade SR charger that charges at the same voltage, but only 0.8 amps. The 450X charger charges at 1.8 amps. Would the Blade SR charger be fine for charging my 450X battery?
I know it would be sloowwww but would this work and be ok for my battery? I have a turnigy charger coming in but it's gonna be a while and in the meantime charging off my car battery is inconvenient.
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote
Old 03-09-2012, 10:23 PM   #2
InFocus
As long as it's a 3cell battery charger, it should work just fine. But like you said, it will be sloooow.
I thought the 450X came with a charger.
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote
Old 03-09-2012, 10:48 PM   #3
lrs5
I tried it. It's not enough amps. The lights blink in a error sequence and the fan pulses. The charger for them450 battery needs to have at least 2 amps I believe. Although it may be 3 amps. Hope it helps.
Helis: Goblin 630c \ Velocity 50 \ 450X
Radio: DX-9
Sim: Phoenix
RCHN Citizen 48
lrs5 is offline        Reply With Quote
Old 03-09-2012, 11:29 PM   #4
TheHeliDude
Thanks irs5. In focus, the 450x doesn't come with a AC adapter. Can only charge off 12V DC. Thanks guys
Old 03-10-2012, 09:49 AM   #5
Chris Wall
My LHS had the AC adapter for the 450X charger in stock for $29.95, it works well (although I hated paying that much for it). I ordered a iCharger and MeanWell unit from epbuddy.com last night so that I can charge in parallel.
Synergy Field Representative / Team Scorpion / Team FBL Rotors / Team OptiPower USA
Chris Wall is offline        Reply With Quote
Old 03-15-2012, 12:38 AM   #6
Talesin
Just curious, is the AC adapter the same one that comes with the Celectra chargers for the 120SR or mCPX? If not, do you have a part number?
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X
Spektrum DX8, DX6i
Talesin is offline        Reply With Quote
Old 03-15-2012, 10:01 AM   #7
Relisys190
The AC adapter is different. It supplies higher power to the charger to comply with the bigger demands of charging the batteries.
Part # : EFLC4030 Blade 450 Charger 3.0-Amp 100-240V (Adapter)
*LINKS*
* G660c IKON * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote
Old 03-15-2012, 03:45 PM   #8
Kumba
I actually just used an old Toshiba Satellite power supply. It outputs 12v at 3.3-amps. Perfect and cost me nothing
Only bad part is it's not the most snug fit in the charger. If you start moving the charger the plug will slip out if you aren't watching. Other then that it works fine.
Kumba is offline        Reply With Quote
Old 03-22-2012, 07:20 PM   #9
Talesin
Just picked up the official one; LHS had it in stock for $22, and all of my laptop chargers appear to be 19V @ 4.7A... hate to over-volt and let the magic smoke (and fire) out.
Added bonus, they finally had 2mm solid CF rod stock come in, so can start messing with my mCPX tail boom length. Still no 3mm though for a new mainshaft. And no 450X tail support strut spares either (3mm CF rods with much tighter manufacturing tolerances).
Spektrum DX8, DX6i
