Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 03-10-2012, 04:35 PM   #1
helidom
Default 450x blades
Hi all, crashed my 450x today need new main gear and boom both cheap, and new blades which seem expensive at 33 a pair, is it ok to use align 450 3g blades (12) and do i need to change any settings in ar7200bx?
helidom is offline        Reply With Quote
Old 03-10-2012, 08:46 PM   #2
mtuccio
The 3G blades are 23 grams each which is very close to the weight of the stock blade. I put the non 3G blades (18 grams each) on mine and had to make some very slight adjustments. Hope this helps....
mtuccio is offline        Reply With Quote
Old 03-11-2012, 07:05 AM   #3
Flying_Amp
I have also heard of others using the Align 3g blades, just solely due to the cost of the 450x blades (the only negative point i have seen about this heli is the cost of the blades)
Flying_Amp is offline        Reply With Quote
Old 03-11-2012, 10:13 AM   #4
helidom
Thanks for replies, i`ll go ahead and get align 3g blades, hopefully all will be ok.....
Old 06-24-2013, 12:43 PM   #5
mekky67
What adjustments were needed?
I've bought some non-3G blades by accident (thought I was ordering 3G) so if they're useable I'll give them a try.
mekky67 is offline        Reply With Quote
Old 06-24-2013, 03:23 PM   #6
Mr.valby
I have align 3g rotor blades on my blade 450x. the quality is very good and the balance is very close. No adjustment but I only 8 fly numbers and circles, no 3d.
Mr.valby is offline        Reply With Quote
Old 06-24-2013, 03:51 PM   #7
audacity
i have had the stockers, rails, raidx, and 3g's. even tho the 3g's were balanced good, the tracking could not be perfected and probably the main reason the heli did not like them! the stock blades are pretty darn good. i do like the rail blades tho i haven't really had the chance to fly em much because i'm fly n my larger copters. i can tell ya the tracking on rail blades is the best i've ever seen!
audacity is offline        Reply With Quote
Old 06-25-2013, 09:33 AM   #8
spiff72
I am assuming that you are looking at these:
https://www.amainhobbies.com/advance...hd320d&x=6&y=3
I bought 2 pairs of them after I crashed my 450X, and flew the first of the 2 pairs for about 2 months before my second crash.
I will be installing the second pair this week, but make sure that you check the dynamic balance of these blades. Both sets of mine needed some balancing effort to get them right.
MCPX BL, 130X, 450X, Nano QX, ProtoX
Spektrum DX7S
spiff72 is offline        Reply With Quote
Old 06-27-2013, 10:19 PM   #9
bmlasater
fwiw...
Align blades work fine.....Are 10 mm shorter than stock, but fly nearly the same...Another good bet is the EBay 3D blades.....Don'tlaugh....$9.95 a pair, and fly great....
John
bmlasater is offline        Reply With Quote
Old 06-28-2013, 03:03 PM   #10
vronny
Originally Posted by bmlasater View Post
fwiw...
John
I just received the 3D pro 335mm from HK USA only $7.42 a pair also have the HK Fiber glass 335mm which also use for $3.50. Just a sport flyer but these blades work for me. Also just received some sets today.
vronny is offline        Reply With Quote
Old 06-28-2013, 08:15 PM   #11
FailureToFly
Never had an issue with Align blades. Balance up great (sometimes perfect out of the pack) and never a tracking issue.
Tracking is due to blade balance and heli setup anyway.
The Aligns are certainly not world class blades compared to the expensive competition but unless you are a 3D master, using cheap blades is smart as why make a cheap little heli crash expensive? For a 450 I prefer under $50 crashes rather than under $100.
They fly absolutely fine and are reliable, stable and provide plenty of performance and snap for all levels of 3D flying.
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote
Old 06-29-2013, 05:46 AM   #12
TomC
Just my opinion but I think that the stock 450x blades are a bit better than the Align 3G blades. They are a bit stiffer and give you a bit more pop (and bark).
Properly balanced and tracked the Align 3g's work fine though.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote
Old 06-29-2013, 06:19 AM   #13
Yakimah
Default 450x blades
I find the stock blades to be very fragile and prefer the align ones, haven't tried that many other blades yet though.
SAB Goblin 700 VBar | Align Trex 550 PRO DFC VBar | KDS Innova 550 | Gaui X3 BeastX | Spektrum DX8
Yakimah is offline        Reply With Quote
Old 06-29-2013, 06:28 AM   #14
spykez
I think the stockers are nice too.
And the one time I got a badly balanced pair, I just picked up the phone to Modelflight (my local, or more aptly, regional, Blade helicrack dealer) and got it sorted,
No worries.
Still in exile. FML.
spykez is online now        Reply With Quote
Old 06-29-2013, 03:10 PM   #15
helifanatic99
The stock blades fly great, but visibility sucks. Any cloud cover at all and the rotor disk disappears. I love the Revolution blades. Same length, fly about the same but they're 3g lighter each and the white tips give great visibility of the rotor disk when it's overcast or clear. Only a couple bucks more than the stock blades. I don't crash all that often, so they're worth it to me and they balance perfectly, which is a huge plus, because I hate balancing blades.
helifanatic99 is offline        Reply With Quote
Old 06-29-2013, 08:50 PM   #16
Psuedo_Heli_Commander
Default 450x blades
I too like the Revolution blades for visibility.. Should note I have flown the Align 3G blades (FBL ones)...but noted mine were packed with a slip that noted max rpm 2800... I have ordered additional Revolutions since..
So many hobbies,interests and places... so little time....
Psuedo_Heli_Commander is offline        Reply With Quote
Old 06-30-2013, 08:13 AM   #17
helifanatic99
Cheers,
TomC
The extra "pop" is because the stock blades are 10mm longer from bolt hole to tip. Align measures from root to tip. Most of the lift is generated at the outer part of the blade where angular velocity (tip speed) is the highest.
Old 06-30-2013, 04:30 PM   #18
JohnCrashes
Default Revolution Blades?
I also like the visibility of the Revolution blades, but they didn't hold up well for me. I had one minor blade tip to my lawn and a 3 inch chip flew off at the tip. I've done far worse to my stock blades and they held up really well.
JohnCrashes is online now        Reply With Quote
