Old 03-11-2012, 10:49 AM   #1
Dr.J
Default T-Rex 500 Motor and Canopy Options
Greetings,
I'm tired of the noisy bearings in the stock align motor and am looking for a replacement. I was set on the Scorpion motor, but understand its bearings need oiling every five, or so, flights; is there not a better option?
I'm using the Zippy 2650 packs and an ICE 100 ESC. I've not progressed to 3d and at this point, just want a smooth and reliable heli.
A Neu motor was suggested and am wondering if anyone has had experience with these, if they're recommended and if so, what motor, in my application?
Lastly, the new T-Rex 550e canopy, will it fit on the 500?
Any and all recommendations appreciated!
thanks,
John
Dr.J is offline        Reply With Quote
Old 03-11-2012, 12:51 PM   #2
ddj74
500 only fits with 500 canopys. My stock 500mx motor isnt loud at all. Why would u want a quiet heli?
ddj74 is offline        Reply With Quote
Old 03-11-2012, 02:42 PM   #3
Wildcards
So you want a motor with smoother, quieter bearings but you don't want to take the minute or so to oil them?
USMC - EXPEDITIONARY AIRFIELDS - MCAS MIRAMAR
Align Trex 500 Scorpion 3226-1400 powered missile
Wildcards is offline        Reply With Quote
Old 03-11-2012, 06:33 PM   #4
Blade120
the 500mx motor is a big improvement over the 500l as far as power goes also comes down so much cooler after flights, noticed it drains the batteries a little more but its well worth it. will be getting a scorpion motor on the next heli i put together no experience with them but many positive reviews on them.
[Trex 450 PRO V2 3GX, Edge] [Trex 500 ESP(DFC) ICE100, 3GX, Edge] [Trex 600 DFC PRO SK-540 ] [Rave ENV Nitro O.S 105-R,Total G,Outrage, Edge SE 713] [Blade 130X]
Blade120 is online now        Reply With Quote
Old 03-11-2012, 06:43 PM   #5
Wildcards
The 500mx is a awesome motor, however if you really like the power of the 500mx do NOT get the 3226-1600, you might be disappointing. I'm running the newer 3226-1400 and I absolutely love it!!! im getting 4.30 min at 100% with a 14t with aggressive flying. the motor comes down slightly hot, about 130-140, and the lipo and ESC under 100, this is on 3000 30c. I'm actually getting about 30 seconds more flight time compared to the 500mx.
Old 03-12-2012, 10:51 AM   #6
Dr.J
Gee, isn't there anyone able to provide a motor recommendation, based on bearing longevity?
Old 03-12-2012, 12:17 PM   #7
Wildcards
Bearings on these motors are a regular wear item. Or u can just upgrade to boca bearings and wish for the best.
Old 03-12-2012, 11:37 PM   #8
Vinger
The NEU or older KDE motor's bearings last forever. Have my KDE motor now for more than 1.5 years, probably 300+ flights, not a single squeal and NO oiling required.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 03-13-2012, 12:20 AM   #9
Wildcards
I personally dont have any issue oiling my bearings, it takes all of a few minutes and I love the way the Scorpion oil smells
Old 03-13-2012, 12:48 AM   #10
Crash549
Are you guys wearing out bearings due to a tight pinion/main gear mesh?
Crash549 is offline        Reply With Quote
Old 03-13-2012, 02:51 AM   #11
pxpep
Buy a Scorpion or Hyperion motor and install double rubber sealed ceramic bearings. Remember to add green locktite between the axle and the inner race. It will last for a looong time with no maintenance.
The same can probably be done with the MX motor. Remember to change the axle too.
pxpep is offline        Reply With Quote
