| X5 Discussion and support of the Gaui X5 |
I hear some of you guys using align tt bearings on the X5.
Can I ask what bearings? And how many are you using..I saw someone was using 2? Where are you placing them on the TT Thanks |
I am using the align trex 600 bearings and rubber retainers. I run two of them.
Team Synergy/Team Scorpion |
Offset! NOT exactly in the middle like stock bearing.
I only replaced the bearing holder for the Align 600 one.
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75 TSH Gaui X5 FES, Mini VBar 5.3 Pro, S.Bus, DS610s, DS650, YGE 100LV Futaba T7C Phoenix R/C v4 |
yeah the 600 bearing holder is waaaaaay softer than the hard plastic one that come stock. i actually had to cut it off, i could not get it off any other way when i went to install my 600 rubber bearing holder.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team A-Main/ProTek Field Rep. |
#6 |
Yes, 600 TT bearing x 2. I put the TT vertically and put a plier on top of the original bearing. Just tap plier to get the bearing out of the TT.
Gaui X5 FES, Beastx, belt tail Protos 500 FBL, lower head, stretch tail, Beastx AleeS Rush 750 (build in progress) |
#7 |
i left the factory one on the TT and just installed a trex 600 rubber holder on it.
will i have issues with just one ?
#8 |
NO Need to remove orginal bearing.
1)Just use the align rubber hold. Cut the Gaui bear holder out and replace it with align bearing holder. 2) Add another bearing or 2 if you like. I got the 2 pack from align and now my tail have 3 bearing supporting the rod all have align rubbers on. Over Kill? YESSS |
#9 | |
#10 | |
i left the stock one alone and added 2 more align600 ones.
time will tell.
"How high does it go?" Love that question..... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 |
Did you replace the stock bearing holder?
#12 |
I'm using only the stock set up with no problems during the first 4 gentle flights.
Gaui FES X5 w/ BeastX, Trex 450 Pro, Blade mcpX BL (dry docked), Blade 130X blinged, Blade msr, JR 9503, Aerofly 5 |
#13 |
Same here. Stock setup and it seems fine. Recently purchased kit with 520 blades, 15T pinion and MB v3. Perhaps something has changed...
Gaui X2 FES ZYX, Gaui 425 FB, Gaui X5 FES MB v3, 250 DFC ZYX, 450 V2 FB, 450 DFC Sport ZYX, ALZRC 450 Pro FBL FU-Bar, Devil 450 FAST VCTRC 3GX, 500 DFC Pro GV8000 VBar, O6 500ESP SDC ZYX-S, 700E DFC HV iKon, O7, 550E DHPS FBL HB800, O9 - ZYX v4 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#14 |
How do you remove pins in the end of torque tube, to install new bearings.
#15 | |
![]() I only replaced the bearing holder for the Align one. If I grab a hammer, stuff only gets worse. ![]()
