Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 03-11-2012, 06:09 PM   #1
audio131
Default adding a 700mx 530kv motor
hi.. i just ordered a align 700mx 530 kv motor for the x50e.. im running the 600mx 510kv on it now and the gears handle it no problem.. heli should be sick with the 700mx..
audio131 is offline        Reply With Quote
Old 03-19-2012, 06:55 PM   #2
audio131
Default 700mx
hi, the 700 mx is sick in this heli. and very effient.. temps are low too...the main gear is super strong. over 20 flights on heli and reall abusing it and not a single problem with the main gear or any other gear
Old 03-26-2012, 04:43 AM   #3
DavidTan
Default cool
Thats Great! thanks for sharing! Was thining to get X50E for my next heli.
DavidTan is offline        Reply With Quote
Old 04-03-2012, 09:25 PM   #4
jhall2242
Audio131 - What batteries are you using?
jhall2242 is offline        Reply With Quote
Old 04-04-2012, 06:19 AM   #5
audio131
Default lipos
right now im using 2 pulse 45c 6s 3300mah packs,, seem pretty good.... heli is still flying pretty awesome.
Old 04-05-2012, 10:56 PM   #6
OnTheSnap
How strong are the TT gears? Can it handle a lot of reversal abuse?
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e
HeliDirect, Team iKon, GrandRC
OnTheSnap is online now        Reply With Quote
Old 04-06-2012, 06:20 AM   #7
audio131
Default gears
so far really good!! very strong.
Old 04-12-2012, 06:00 PM   #8
jhall2242
I was going to try to run a 6S setup with an Align 600MX 1220kv motor and 100amp Castle that I already had. That should have put my headspeed around 2700 which from what I read is way too high. What head speed is good for this heli?
Old 04-12-2012, 07:28 PM   #9
audio131
Default x50
2400-2450 really makes it pop..if u keep it light it will pop with less head speed than that... 2700 is a bit too high.. try another pinion size.. word of caution.. only x50e pinion fit in this heli...
Old 04-13-2012, 07:30 AM   #10
gwright
I'm a bit of an oddball and run far lower rpms than most as I like long flight times with adequate power for smooth "freestyle" (90's era 3D), not ballistic power. The last we tached it my two flight modes were 18100 and 2000. 10S/3800 packs take 2500~2600 each on recharge after 6 minutes, so I should reset timer to 7.5 or so, and 8~8.5 with the 4350's. The damping was designed for the more common higher rpms, so it's a bit stiff in this range, but OK. Don't know how much lower you could go before you'd get nodding, and of course blades have an affect on that too.
gwright is offline        Reply With Quote
Old 04-20-2012, 06:47 AM   #11
Spindle
audio131 what pinion and esc r u using with the 700MX?
Spindle is offline        Reply With Quote
Old 04-20-2012, 11:17 AM   #12
audio131
Default pinion
15t on fixed end point ...or 16t govened
Old 04-25-2012, 12:29 PM   #13
Spindle
Cool, thanks
