Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-11-2012, 11:20 PM   #1
Alexandre Najar
Default Which bec!?
Hi guys, I just have ordered my new Trex 500 EFL Pro and I would like to ask about the align bec. Is it good? And how about its governor function? I am asking this because I have a Trex 500 ESP and I bought for her a Phoenix Ice bec that is great! Should I do the same for this kit? Thank you in advance for any opinion!
Alexandre Najar is offline        Reply With Quote
Old 03-11-2012, 11:48 PM   #2
Deet
The BEC in the Align ESC is better than the CC BEC.
The Gov in the Align ESC is worse than useless
HOWEVER, the Align ESC works perfectly with the vbar Gov
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 03-12-2012, 12:04 AM   #3
Alexandre Najar
Please, correct me if I am wrong, but the 3gx has a gov function, doesn't it?
Old 03-12-2012, 01:24 AM   #4
Deet
not for electric helis i believe
Dave
Old 03-12-2012, 03:48 PM   #5
Steemo
If you are concerned about having a good bec get a CC BEC Pro and be done with it
T-Rex 700E DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro | T-Rex 500 DFC Pro AR7200BX
JR DSX9 LE Mode 2
Steemo is offline        Reply With Quote
Old 03-12-2012, 07:38 PM   #6
Alexandre Najar
Guys, I think that I was not clear, sorry! My doubt is if I can change the original Align esc to the CC phoenix ice esc! I saw in a YouTube video that the 3gx flybarless unit has a gov mode, or I am wrong. I really like to fly in gov mode! Is there any problem to use a CC with the 3gx unit?
Old 03-12-2012, 08:01 PM   #7
Steemo
lol, that clears that up.
The 3GX governor is designed to be used with nitro motors not electric.
As for the CC speedy I assume you are talking about the ICE 80?. I think it has its own governor built in but I have no experience with governors so can't help you.
It's all electrical wizardry to me
That being said apart from guys doing smack down 3d most pilots using electric set-ups just run flat throttle curves (N=0,40,80,80,80 St1=90,90,90,90,90 St2=100,100,100,100,100)
These work well for me.
JR DSX9 LE Mode 2
Old 03-12-2012, 09:50 PM   #8
cadkins
I'm putting a ICE100 on mine - Descent governer, data logging, and 5 amp BEC.
BTW - I had 189 flight on my 500ESP with the stock Align ESC using it's BEC. It did not have a governer but was a solid controller.
T-REX 450 PRO V2 - Align 450MX / HS-5065MG & DS520 / ICE 50 / AR7200BX
T-REX 500 EFL - Align 500MX / Align DS510M & DS520 / ICE 100 / AR7200BX
T-REX 600 EFL - Align 600MX / Align DS610 & DS650 / ICE 80 HV V2 / AR7200BX
cadkins is offline        Reply With Quote
Old 03-13-2012, 09:02 PM   #9
Alexandre Najar
Now I understood! I will really need a phoenix ice esc on my new bird! I have already one in my old 500 ESP and it is great! Thanks for all!
Old 03-14-2012, 02:16 PM   #10
cadkins
You dont really need it but if you have the cash it's a nice option IMO.
Old 03-14-2012, 08:37 PM   #11
NRPY
I use a Jive 80LV and its built-in BEC on my 500 Pro. This ESC just barely fits under the battery tray. I am very happy with its performance.
NRPY is offline        Reply With Quote
Old 03-15-2012, 05:42 AM   #12
cadkins
Good point the Ice75 or 100 will need to go on the side of the heli. I think the Ice-lite will fit under the battery tray.
I selected the Ice100 and will be mounting it on the side of the frame under the main gear. It will stay very cool and aid in fixing the forward CG.
Old 03-15-2012, 07:29 AM   #13
Andy from Sandy
The Jive 80LV and CC 100 seem way over-kill to me when the stock kit is supplied with a 70A esc. If I was going Kontronik I would go for the Koby 70.
Andy from Sandy is offline        Reply With Quote
Old 03-15-2012, 10:08 AM   #14
Alexandre Najar
For those who use CC ice with a trex 500efl pro what head speed you fly? I am asking this because the align kit comes with a 12T helical pinion and from my experience to run at 2600 or above you will need a 14T pinion for the CC software to accept this hs and I can't find where to buy it!
Old 03-15-2012, 01:17 PM   #15
Andy from Sandy
You need to look at the gear ratio not just the pinion size. Plug some figures into the MrMel headspeed calculator and you will see. I have set mine to 2700 as that keeps the stock ESC running cool.
Ungoverned it will easily go over 3000.
Old 03-15-2012, 07:55 PM   #16
NRPY
I run mine @ 2800 RPM governed with the Jive. Can't go much higher without a larger pinion.
Actually, I wouldn't want to go any higher. The performance is great and I'm only getting around 4:30-4:40 fight times with a 2700 mah battery (which is the largest I can use).
Regarding the Jive being overkill - perhaps, but it has a much better BEC than the Koby, which I felt was important for best FBL performance with minimal weight.
