Old 03-12-2012, 05:22 PM   #1
terra
Default one day great next day all over the place ?
What happened , i finally get some help to find tune my 550E 3G and get it flying good , a friend also did some hard 3D to show me there was nothing wrong with the heli , and i was now the only problem ,,nice to see your own heli put through its paces ,,
Next day i go out to fly alone and the heli goes up into a very unstable hoover moving left and right needing serious opposite stick ,,So i land it before i loose it ..what could have happened ???
terra is offline        Reply With Quote
Old 03-12-2012, 05:57 PM   #2
helicopter1
Could be the mounting sticker on gyro
helicopter1 is offline        Reply With Quote
Old 03-12-2012, 06:33 PM   #3
BIG JOSH
Did you bump it when starting? Did you let it initialize? It should pump 3 times.
BIG JOSH is online now        Reply With Quote
Old 03-12-2012, 09:58 PM   #4
farleys04
Don't know the weather there but I tried to fly my 3G in the Cold(38 Deg.) and it acted really weird. Flew it Sunday when Temps was back to normal (60 Deg.) and it flew great.
farleys04 is offline        Reply With Quote
Old 03-13-2012, 03:32 PM   #5
terra
when my friend looked at it first time i had it strapped down to try to solve problems and one of the things he did to get it to fly great was remove the strap ,,but now it looks like the aileron instability is probably due to vibrations and i should strap it again !!!!
Old 03-13-2012, 03:33 PM   #6
terra
you don't think i should start to play with the aileron gain screw ??
Old 03-13-2012, 04:41 PM   #7
helicopter1
Stap it down again and see if that works
Old 03-14-2012, 04:10 PM   #8
terra
oh how stupid do i feel !!!!!! i have just realised that we copied the model to the chip in my 14MZ and i used the old model saved on the TX with none of the new modifications ,,,Of course as soon as i loaded the correct model it was perfect again ,,sorry to waste your time but all is well now
Old 03-14-2012, 05:09 PM   #9
helicopter1
