Old 03-13-2012, 08:13 PM   #21
CousinLarry
Have you replaced the tail motor wire completely? Are you sure you have a good plug connection on the motor wire and board? I tinned the prongs on mine because it pulled out easily, worth checking if you haven't already.
CousinLarry is offline        Reply With Quote
Old 03-13-2012, 08:45 PM   #22
N4HHA
I run 67 on pitch to help prevent blowouts. Still plenty of lift when I need it. Set via testing since day one.
B120SR BSR HK450 FBL 450/Align 3G
mCP X Draganflyer Quad
DX7
N4HHA is offline        Reply With Quote
Old 03-15-2012, 01:40 PM   #23
AV8TRX
I had a similar problem, come to find out the tail rotor connection plug had backed out enough that the connection was being fully made. I am not sure if this applies in your case but maybe there is another T/R wiring issue. I wish you luck.
mCX2, mCPX, DX4e, Phoenix3 sim
AV8TRX is offline        Reply With Quote
Old 03-15-2012, 09:31 PM   #24
CyberPlainsDrifter
Location: Burnaby British Columbia - the most expensive place on earth!
Funny, I usually fly a 12 battery rotation.. My 200's all began to die at once..
I would take off, punch it and the bird would fall out of the sky... Okay, tray again...
Same thing... hmmmm.. maybe its a battery???? add new batter. takeoff. punch it and again it fell out fo the sky.. dammit...!
After about four differnt cells all doing the same thing.. I tried a new 300 nano and all of a sudden!!!! ZEN!!!!
so.. yeah..
Good luck Napoleon.. I hope you find the truoble..
My other suggestion would be to COMPLETELY dismantle the bird.. check ALL the parts that you can.. This is a great way to inspect for hidden damage that might be the culprit.. and as well it offers peace of mind because you now know what is what...
again Good luck!
CyberPlainsDrifter is offline        Reply With Quote
Old 03-15-2012, 10:22 PM   #25
Napoleon_Tanerite
I'm going to try some different batteries this weekend, hopefully that does it.
Napoleon_Tanerite is offline        Reply With Quote
Old 03-15-2012, 11:14 PM   #26
whodothevoodoo
Drop your pitch settings to between 66 and 70. The heli will still fly great, and you'll get less blow out.
I don't think it will really solve all your problems but it will help.
whodothevoodoo is offline        Reply With Quote
Old 03-31-2012, 02:15 PM   #27
intro
Default Size matters
On the Batteries Bigger iz Better, those 300's kick booty, but might mask the problem...with some interesting (read: sucky) results. Good luck.
+1 on the mainboard/tail rotor plug backing out. Been there crashed that.
If it's too nice to throw around, SELL IT!
Blade-T-Rex-Tarot- 450 and under-DX6-AMA#977655
intro is offline        Reply With Quote
Old 03-31-2012, 02:22 PM   #28
superjet112x
Do you have an extended tail boom and useing the V2 tail rotor? If not extend your boom to 140mm and try a V2 tail rotor not the KBDD they dont work as well
Trex 700n DFC Beast x...Trex 600n Beast x...
Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50
MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx
Blade 300x Phoenix 25esc Park BEC Blade upgrades
Ducati Desmo 1/5 scale nitro superbike
superjet112x is offline        Reply With Quote
Old 03-31-2012, 02:24 PM   #29
intro
Old 03-31-2012, 02:36 PM   #30
intro
