Old 03-12-2012, 09:42 PM   #1
3dflyboy09
Default Breast x drift
i have a trex 450 pro v2 flys great but is alway drifting backward ar7200bx says to not use any trim so how can i stop the drift.
3dflyboy09 is offline        Reply With Quote
Old 03-12-2012, 10:46 PM   #2
Bob O
Member
What kind of mounting tape are you using? You might consider a velcro strap around the FBL unit.
Bob O is offline        Reply With Quote
Old 03-12-2012, 11:10 PM   #3
3dflyboy09
Default drift
just using stock but will try strap could swash levelness or cg play a roll in this swash seem pretty good to my naked eye though
Old 03-12-2012, 11:24 PM   #4
crf69
i recommend 3M 4011 2-sided tape.
red backing with grey sticky
gainzzz-r-us
crf69 is offline        Reply With Quote
Old 03-12-2012, 11:36 PM   #5
cpmboy
upps....sorry ...I though a new category.....''''breast x...".....
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote
Old 03-13-2012, 12:08 AM   #6
infamousnation
You probably will want to get a tool for leveling your swash, it's worth it. Checking cg is pretty easy, just pick the heli up by the blade grips and then hold it so the main shaft is parallel to the ground. It should not tilt forward or back. Checking for vibes is pretty easy. Take off main blades and tail blades. Spool up the heli and run it at different speeds. Watch for any servo movements. The littlest vibration can cause the beastx to think the heli is rotating when it's not.
Mcpx/Trex250/HK450/Protos500
no flybars allowed/Beastx ftw
infamousnation is offline        Reply With Quote
Old 03-13-2012, 05:39 AM   #7
highlightshadow
Well, assuming you setup menus G, I, J, K, L & M ok for swashplate levelling, geometry and limits etc
Then you use parameter menu A to adjust like you would sub-trim assuming you cannot shift your battery forward for example to adjust the CoG forward to counter back drift.
Hope you get it sorted!
highlightshadow is offline        Reply With Quote
Old 03-13-2012, 12:32 PM   #8
tomd27858
+1 and check your swash with a leveler.
Team HeliDirect
Flying Align - Powered by Pulse
tomd27858 is offline        Reply With Quote
Old 03-14-2012, 12:13 PM   #9
fuzzyllamma
If none of these work, try going into setup parameter E (stick deadband) and reducing it. I had a similar issue and one click down solved my problem. You may need to go more or less. It could also no solve your problem but try it if all else faile
fuzzyllamma is offline        Reply With Quote
Old 03-15-2012, 11:36 AM   #10
GeKu
Default "Breast x"
Your "Breast x"? Are you sure it is drift, and not bounce? lol sorry I couldn't resist
GeKu is offline        Reply With Quote
Old 03-15-2012, 03:07 PM   #11
Harbormaster
Have you tried an underwire bra for better support?
Harbormaster is offline        Reply With Quote
Old 03-16-2012, 10:10 AM   #12
chrismechanic
or a sport bra could help...so the wife says
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote
