Closed Thread
Old 03-13-2012, 08:42 AM   #1
hobdean
Default Trex 500E What Pinion and poor Manual
I think the pinion is 13t Mod 0.6. Mod is the most important part. Just want to be sure before I strip all my gears. It is not in the manual.
hobdean is online now
Old 03-13-2012, 10:17 AM   #2
OC Heli Tech
if its a pro!
Specification(T-REX 500EFL PRO Super Combo):
Length: 868mm
Height: 300mm
Width: 161mm
Main Blade Length: 425mm
Main Rotor Diameter: 978mm
Tail Rotor Diameter: 206mm
Motor Drive Gear:12T
Main Drive Gear:134T
Autorotation Tail Drive Gear: 145T
Tail Drive Gear: 36T
Drive Gear Ratio: 1:11.17:4.03
Weight(With Motor): 1210g
"If you're not crashing, you're not flying"
T-Rex 450, 500, 550, 700E JR9503 2.4 Micro Beast
Ochelitech.com
OC Heli Tech is online now
Old 03-13-2012, 12:32 PM   #3
hobdean
Not a pro. It is a KX 017014T 500E, belt driven. Any help would be appreciated. There is nothing in the instruction manual about pinion type. Of course depends what motor and what rpm. I just want to know the Mod part is suppose to be to get the mesh correctly I assume.
Closed Thread
