Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 03-14-2012, 03:20 AM   #1
ddj74
Default KDE Performance tail and Carbon Fiber Push Tail Mod
So after many hours of trying to figure out how to put together this tail with poor directions (hard to see illustrations) i finally completed the modifications. Another drawn back was breaking loose permanent lock tight from previous owner on a few parts. Good thing i bought a mini torch. Installed is...
AT500-PTC & AT500-PTU-V2 KDE performace tail kits ($75.99)
TX55T24-BK Quick UK T-Rex 550 Carbon Tail Pushrod Kit ($35.99)
Nothing to say about the tail kit pretty much straight forward but gotta have midget hands to work with getting the bearings and washers in place.
As far as the carbon fiber tail rod only modification i had to do was cut about 6 1/2 inches to make it shorter and not use the tail clamp that came in the kit. Not needed anyways because its sturdy enough and less friction. Everything came out perfect and very clean looking. Next i will probably buy a pro blade holder. Purpose of this was to eliminate play and vibrations. Also the guide rod was a little squeaky...lol.
Anyways here's a link to my album with the pictures of before and after...
http://www.helifreak.com/album.php?albumid=8764
AMA #1039539
ddj74 is offline        Reply With Quote
Old 03-14-2012, 03:33 AM   #2
flerpie
So does the forked tail slider reduce the play in the slider assy?
The side2side wobble of the slider?
That's what I'm after. Hope they ship mine soon.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 03-14-2012, 03:46 AM   #3
ddj74
Very impressed with the quality and big improvement on slop. Now one annoying thing about installing this kit is you have to grind a little around the blade grips where they attach to the slider to set right on the bearings...
http://www.kdedirect.com/files/KDE_D...V2_Design4.pdf
AMA #1039539
Old 03-14-2012, 05:15 AM   #4
flerpie
Yes, I saw that. Evidently the KDE design was done and finalized
before knowing the shape of the new grips had changed.
How much chamfer did you have to file on the grips?
Is there any way to file the KDE side of things instead of the grips?
I hesitate to file on grips because they will not be as close in weight
after I file on them...I be no metal worker.
Can you show us a closeup of the filing you had to do?
Build Different!
Old 03-14-2012, 05:13 PM   #5
torpedoarmed
Why not just use the 500 Pro CF rod? it is only 12.95 with the holder too. Take it to a archery shop and trim down about 40mm, take a heat gun to losen the collar and stud for ball joint, some CA and your done.
torpedoarmed is offline        Reply With Quote
Old 03-14-2012, 06:32 PM   #6
Deet
rather than $36 for the 550 CF rod...
buy a pice of CF tube, about $5, cut a spare link rod in half, and JB Weld the rod ends into the CF tube. Done
Thats all I did.
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 03-14-2012, 08:30 PM   #7
Blayd
+1.. thats how it was done on my ESP. I plan on doing my other 2 500's next week.
Trex700N2E
Trex500ESP (Belted)
HC500SE ....GO TEAM FLYBAR!
Blayd is offline        Reply With Quote
Old 03-14-2012, 09:31 PM   #8
ddj74
Why take it to a archery shop for? Nothing a Dremel tool and tape can't fix. I liked the 550 kit because it came unassembled so i could easily cut to size. Made the rod in 10 minutes. Very rigid and only 2 grams more in weight then stock. I didn't want the holder to begin with cause it's useless and creates more friction.
AMA #1039539
Old 03-14-2012, 09:33 PM   #9
ddj74
Thats all I did.
As much money i've put into this thing i don't wanna chance it. Plus i don't want it to look homemade...lol.
AMA #1039539
Old 03-14-2012, 09:38 PM   #10
ddj74
You can't modify the KDE end because the grips contact on the center of the bearings...here's a picture of grip. You don't need to be a rocket scientist to modify the grip. A nail file works perfect...
AMA #1039539
Old 03-15-2012, 01:24 AM   #11
flerpie
Thank you ddj....Now I have a real idea of how much will need to be
removed from the grips. I don't have the KDE lashup in my hands yet.
Maybe version 2.0 of the KDE pitch links will have a slightly larger diameter.
Build Different!
Old 03-15-2012, 02:48 AM   #12
Deet
no version 2 links are made for the old grips
Dave
Old 03-15-2012, 08:06 AM   #13
snjbird
I like that KDE upgrade, I have been considering trying one, I just don't know which one to try... might give it a go on my 12S 600, keep us posted on how it works out for ya DD
snjbird is offline        Reply With Quote
Old 03-15-2012, 09:24 AM   #14
torpedoarmed
Thats all I did.
Actually a good idea Deet. I especially like using the spare link rod. One thing In hindsght I wish I had doen was maybe use a longer stud for the ball joint. The one that came with the rod was maybe 20mm long and I gluded it back with CA.
Hindsight is the vibes that it will suffer, will the CA may not hold and not crack over time and maybe let the ball joints go loose.
Old 03-15-2012, 09:29 AM   #15
torpedoarmed
I could have dremeled it but at a the archery shope, they have a jig that makes a perfect square cut on carbon fibre shafts.
I would suggest taking a second look at the holder. My thoughs are that during travel on both ends, deflection will occur wihtout something between them to maintain alignment. As for friction, its nile at best, my alignment has teh tube floating inside teh holder at station keeping.
Old 03-15-2012, 05:30 PM   #16
Deet
Mine has been working perfectly with 0 deflection of 18 months. You really don't need a holder for this length of rod at all.
Dave
Old 03-15-2012, 06:41 PM   #17
Mateyhv
By the way I guess you can exchange this one:
http://www.kdedirect.com/TREX500PTUV2.html
for that other:
http://www.helioption.com/store/inde...products_id=92
Half the price
Mateyhv is offline        Reply With Quote
Old 03-15-2012, 11:44 PM   #18
ddj74
Got to test it out today and tweaked. Was able to increase my gain from 65% to 80% without tail wag. Then again i didn't test without the carbon push rod so i can only say both mods let me increase 15% gain in HH.
Next going to order pro grips to get rid of the slop on them unless there's a mod i can do to make them better.
AMA #1039539
Old 03-15-2012, 11:46 PM   #19
ddj74
for that other:
Half the price
Damn wish i seen that...oh well guess i'll order those with the pro grips. Quit spending my money
AMA #1039539
Old 03-16-2012, 01:46 AM   #20
Deet
the pro grips also have slop, and you need the pro hubs as well
It you rally want to get rid of the hub slop (i think its a good thing to have a little play)
All you need to do is use a file to take a few thou off each end of the hud, Keep the end square and don't file off too much
Dave
