Go Back   HeliFreak > R/C Batteries and Charging Support > A123
A123 A123 Battery Support
Old 06-28-2007, 08:16 AM   #1
csell
Default Want ESC for minimum 8s a123 / 7s Lipo.
I am a newbee and my T-rex 600 just flew its first fligth.
To get a loot of flying time I consider to bay
2 new 6s 4900-5000 mAh lipo packs
or
4 dewalt a123 packs = 5 psc 8s a123 packs + a new ESC.
I hope that five 8s a123 packs will provide more and nearly constant flying time.
But I don't think the stock align ESC can handle the voltage of 8s a123.
Can any confirm that I need a new ESC that can handle minimum 8 x 3.6 volt = 28.8 volt equal minimum 7 Lipo ( 7 x 4,2 = 29,4 volt ).
Any advice or suggestion to what ESC to try is very welcome?
I live in Europe and support for local products is better,
but I will consider baying from all over the world.
Will it be better if I get a 600XL motor insted of the 600L?
Regards Carsten
csell is offline        Reply With Quote
Old 06-28-2007, 10:47 AM   #2
uragano47812
If you want to go >6S you will need to change ESC and the choices are CC85HV or Jazz 55A or 80A. But if you go with CC85HV i read that it has problem with stock align motor but not for sure...
Logo500SE Vstabi-Neu 1910H/1Y-12T mod.7-s9451-s9254-EDGE 603-8s
Logo7003D Vstabi-Scorpion 4035-500-Jive80HV-DS620-BLS251-Radix 690-105-12s
Trex 450 Pro - Gaui FBL Head - Mini-V
Spektrum DX7
uragano47812 is offline        Reply With Quote
Old 06-28-2007, 10:57 AM   #3
waelo
Hello,
I use CC HV85 together with 600L and 10S A123. Works good so far but only running the engine at 75% throttle so it will survive til I get a NEU... :?
STOP SMOKING - FLY ELECTRIC!
waelo is offline        Reply With Quote
Old 06-28-2007, 07:20 PM   #4
Mercuriell
No the stock Align ESC is very unhappy with 8S A123 - most likely due to the cell count function. Although the nominal voltage is 29.2V this falls under load to around 24V. Get a CC85 or if you want something a bit cheaper this one does nicely:
http://www.wattsuprc.com.au/product_...p?pid=EW-HV80A.
As far as the motor goes I ran a 600L motor for around 30 flights on A1238S and it seemed happy but one day it smoked out - I had a binding TT at the time so this may have contributed.
John
Mercuriell is offline        Reply With Quote
Old 06-30-2007, 04:08 AM   #5
csell
Hello.
Thanks for all your answers.
I need a new ESC for sure.
Waelo and Mercuriell do you know what kind of fligth times do you got in hovering and ligth beginners flying?
And how can I compare fligth times for 10s a123 running engine at 75% with 8s a123?
Is it better to consider a 600 XL?
Regards Carsten
Old 06-30-2007, 07:23 AM   #6
Mercuriell
About 5 mins flying on 8S in light flight - the A123 drop their bundle really quick - over about 20secs towards the end of the charge, so you do have to run them on a timer. They are a bit lighter than the lipos so I think running two 8S packs in parallel an attractive option - haven't tried 10S A123 yet but I think that is going to be good Of course you can charge 'em up at 4C although I find 2C better and they really don't need balancing - I ended up taking off the taps when I re-heatshrunk my 8S. They reportedly have a long life too - I'm up to about 100 cycles on my oldest pack which is still going strong.
John
Old 06-30-2007, 04:17 PM   #7
waelo
Originally Posted by csell
Hello.
Regards Carsten
Hello neighbour :wink:,
I get around 7-8 minutes easy flying with my 10s A123 pack, preatty ok i think. Havent fly it as much as Mercuriell tho, you know we dont have that good flyingweather as they do down under...
Br Johan
Old 07-01-2007, 01:13 AM   #8
csell
Hello.
Waelo has 7-8 minutes easy flying with his 10S a123 packs, I don't need more.
I am going to bay some.
Mercuriel, you haven't tried 10S A123 yet but you think that is going to be good.
I paid yesterday for 2 a123 cells I got on a ebay auction, the seller is from Australia, I don't know how many a123 packs you have and how it are asembled, but if you want to try 8s + 2s packs, I can try to get it shipped directly to you?
I just ordered it to learn more about a123 cells, but as I already now have deceided to bay some 10s a123 packs, I don't need it in the near future. If I suddently need 1 or 2 cells I will then ask you to send some to Denmark. I will send you a PM for exchanges of postal adresses.
In selecting the right ESC the best setup will be, if I just can just swap my 6S 4900 mAh FligthPower pack with a 10S a123 pack and may be select another setup in my Futaba 9CHP/FF9 transmitter. I don't know if that is possiable?
As I understand will a lower number of cells gives more current out of the ESC for the same power.
Waelo, how had you limit your setup to 75% power, and can it be done in other ways? Do any know how much power the ESC need to handle under this 75% power setup?
waelo use CC HV85 and Mercuriell use EW-HV80A I will consider both, but I found
JAZZ 55-6-18 for a good prise here in Europe.
Do you think it can handle the large output current when using the 6S Lipo?
Is it a option to consider?
Regards Carsten
Old 07-01-2007, 09:33 AM   #9
kgfly
Hey Carsten,
A few figures to consider:
Lipo cell = 4.2V peak, 3.7V nominal, 3.6-3.2V under load
A123 cell = 3.6V peak, 3.3V nominal, 3.0-2.5V under load
6s lipo: 25.2 peak, 22.2 nominal, 21.6-19.2 under load
8s A123: 28.8 peak, 26.4 nominal, 24-20 under load
10s A123: 36 peak, 33 nominal, 30-25 under load
It seems to me that you cannot gear the heli for both 6s lipo and 10s A123 and be in a safe operating range for the ESC. Remember that most (all?) ESCs are inefficient below about 80%. Even under heavy load the 10s A123 minimum output voltage is almost 20% above the maximum for the 6s lipo. Under light load, like when spooling up, it is close to 40% higher. You could try running your ESC at low throttle on the 10s but I don't know how well it would work, you could end up cooking the ESC.
As for the Jazz I think it is too low a rating. 6s lipo @ 55A = ~1200W, 10s A123 @ 55A = ~1400W. A T600 needs 1800-2200W capacity for 3D. I think you need a 75A ESC at least to be safe from overloading/overheating.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is online now        Reply With Quote
Old 07-01-2007, 03:11 PM   #10
csell
Hello.
Thanks Kgfly.
I found and read more information for both CC HV85 and EW-HV80A.
I live in Europe and a EW-HV80A + programming card must I order from Australia and I can order a CC HV85 from USA for just 20 US$ more, it is better known in Europe, so I have deceided bay a CC HV85, but what is the problem with CC HV85 and 600L uragano47812 writes about?
When I se you numbers I don't condsider to swap between LIPO and a123 anymore.
I will go for a a123 setup only. But how many a123 cells can I connect to a align stock 600L? I think that is the importent questen. Is it 7s, 8s or 10s? What can you recomend?
When I read about a123 cells in a T-rex 600 some thinks that a 2p setup must be ideal. But I can't find any having succes with it? And I am wondering why.
I don't think it can be to heavy. If I want a 7s2p or 8s2p setup I can have 10 cells ( 700g ) in the battery holder and the remaining 4 ( 280g ) or 6 ( 420g ) mounted underneath in center of gravity. The T-rex 600 can easely carry that weigth.
Can any se what the problem then is?
Regards Carsten
Copyright © 2004-2009 - William James - Helifreak.com
