Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 03-19-2012, 04:57 AM   #21
Bladecpnitro
Does the G210 Gyro get the job done or are people upgrading that as well. It looks like Eflite has a pretty nice gyro there. I was thinking of trying one on my Trex 450 clone.
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom
Bladecpnitro is offline        Reply With Quote
Old 03-19-2012, 08:00 AM   #22
Thalios
It is decent, but has issues with backwards flight.
Good beginner to intermediate gyro.
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is online now        Reply With Quote
Old 03-19-2012, 01:54 PM   #23
browndog
Ummm correct me if I'm wrong The BeastX is the gyro on the 450X not the G210!
browndog is offline        Reply With Quote
Old 03-19-2012, 02:00 PM   #24
Thalios
You are correct. The AR7200BX acts as the gyro for the 450X.
But I think he was asking about the gyro on the B450 3D which is the G210.
All on DX18!
Old 03-19-2012, 02:53 PM   #25
FuntanaS
Has anyone tried the Solar servos from Hobbypartz? The D654 looks like a good fit for the 450.
http://www.hobbypartz.com/33p-solarservo-d654.html
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote
Old 03-19-2012, 03:18 PM   #26
DoctorJ
Looks good but t super slow servo.
heres the ds76t
  • Servo Type DigitalServo
  • Voltage:4.8V only
  • Application:Sub-micro and Micro-sized helicopter tail servo
  • Torque:11.1 oz-in (0.80 kg-cm) @ 4.8V
  • Speed:0.03 sec/60º @ 4.8V
  • Length:0.90 in (23.0mm)
  • Width:0.45 in (11.5mm)
  • Height:0.96 in (24.0mm)
  • Weight:0.27 oz (7.6 g)
  • Motor Type:CorelessGear Type Plastic
  • Size Category:Minis and MicrosSpeed (at 4.8V):.01- .04 sec
  • Torque (at 4.8V):Less than 20 oz-in
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - CC 50
Blade 130x - HP08 - CC ( many others )
DoctorJ is online now        Reply With Quote
Old 03-19-2012, 03:45 PM   #27
FuntanaS
The DS76T is the tail servo not the cyclic servo. The DS76 has a speed of 0.11 at 4.8 volts while the Solar servo has a speed of 0.12 at 4.8V. I can't imagine you would notice a difference.
Old 03-19-2012, 05:17 PM   #28
DoctorJ
Opp's,s my bad was not paying attention.
Old 03-20-2012, 10:45 AM   #29
distructor
Any thoughts on the Spektrum H3000?
distructor is offline        Reply With Quote
Old 03-20-2012, 03:12 PM   #30
Thalios
If they are anything like their big brothers the 5010 and the 6080G, they should be awesome!
I actually prefer spektrum servos to hitec servos. Seems better built (body) and are generally more torquy.
All on DX18!
Old 03-20-2012, 03:36 PM   #31
Kumba
How do they hold up compared to the hitecs otherwise? Translation: in a crash
Kumba is offline        Reply With Quote
Old 03-20-2012, 07:42 PM   #32
distructor
I'll take one for the team. Ordered 3. Now to find a descent tail servo. The OEM is fast.
Takeoff is optional, landing is mandatory.
Blade MSR, MSRx, MCPX*4, B450x+HC3SX, Protos 500 stretched+Brain, Century E640+HC3SX
Old 03-20-2012, 07:57 PM   #33
Kumba
Yeah, I've already got 2 out of 3. Picking up the third tomorrow. Just trying to reinforce my impulse buy
I've actually had no trouble with the OEM tail servo so I will just run it till I do. It's the only servo that hasn't been rebuilt at this point.
Old 03-20-2012, 08:46 PM   #34
GasNerd
@distructor I am running Spektrum H3000's on my 450x.
I had two H3000's on hand so I threw them in the 450X after I destroyed the stock servos on a minor blade strike - They hold up well and are priced good. I ordered 3 more as back-ups.
Whiplash 90N | Goblin 500 | Gaui NX4 | T-REX 600E PRO DFC | T-REX 550E V2 | Blade 450X | Blade 130X | MCPX BL | DX8 | BeastX | MSH Brain/Ikon | SK720
GasNerd is online now        Reply With Quote
Old 03-20-2012, 09:09 PM   #35
cwall64
What is the difference between the H3000 & H3020?
T-Rex 700E DFC HV (Outrage BL9180 & BL9188) V-Bar Silver & KDE700XF
T-Rex 700E DFC HV (Outrage BL9180 & BL9188) MSH Brain & KDE700XF
T-Rex 600E Pro DFC MSH Brain & KDE600XF
cwall64 is online now        Reply With Quote
Old 03-20-2012, 09:56 PM   #36
Kumba
3020 is a lighter weight, lower torque, but slightly faster servo. The H3000 is a perfect match for the DS76 servos as far as speed goes and actually higher torque. They are almost twice the weight since they are ball-bearing with full metal gears. In total about 34 grams more for a set IIRC. Also has a cored motor and an aluminum middle body section to act as a heatsink.
The set I bought was $35 which is the same price as the HS-5065MGs but it's a better servo as far as paper is concerned. Hopefully they handle themselves in a crash as well as the HS-5065MGs too. Such is my hope.
If I am off base someone please enlighten me. Always room upstairs to learn
Old 04-12-2012, 11:22 PM   #37
meatwad99si
Automotive technician - but really a rocket scientist
I figured I would bring this thread back as im about to buy some new servos for my bird. Im thinking of getting the H3000. Should I upgrade my tail servo too? It didnt get damaged in the crash. And if so which speky should I get? I wish i could get the mks but spending 3/4 the price i spent on the whole heli just for servos doesn't make sense. Or should I just get the Hitec? ahhhhh decisions decisions...
meatwad99si is offline        Reply With Quote
Old 04-13-2012, 04:40 PM   #38
TheHeliDude
I've had 2 crashes on the h3000s now and they are holding up great. Broke a servo arm but I just flipped it over and used the other side. Thinking about upgrading the tail servo though cuz I get wag in backwards flight
Blade Mcpx - Spin 16.3 - all MicroHeli
Blade Mcpx BL, Blade 130X - HP08
Blade 450X - Scorp 2221-6
DJI F450 Naza, Trex 500 DFC
TheHeliDude is offline        Reply With Quote
Old 04-14-2012, 05:34 PM   #39
profilefan
Friend used these on his 450 3d but they are out of stock.
http://www.hobbypartz.com/9gexidimeges.html
Trex 500 Pro DFC
Blade 450x (Next-D Scorpion 8)
Bl Mcpx (HP06V2/ HP03T), Bl Mcpx (TA915/ HP03T)
Bl Ncpx (HP03SPE/ HP02T)
profilefan is offline        Reply With Quote
Old 04-14-2012, 09:19 PM   #40
FuntanaS
Yeah, hobbypartz doesn't have anything I want in stock. I was looking for some servos, blades, batteries and power supply. All out of stock and for a long time now. WTF?
