I am looking to upgrade the standarad 35g esc into something a bit better and have no idea what to get . I run the xl motor and use flight power evo 25 2170 batteries. I am getting into 3d and i hate bogging the engine.
Should i use a 45 amp system. Where i live it gets real hot in summer. ie 40 degrees c plus. So this is why i want a system with plenty of headroom. I am thinking castle creations have a good rep but am not sure which one is best suited. If you could recomend a few esc and where is a good place to get them from that would be great. Thanks heaps |
Go the Kontronic Jazz 40-6-18, is a little more expensive but it does a great job. It has a very good internal SBEC and runs the servos at 6.0V (nice and fast) the govenor is amazing at keeping the HS where it is set.
You can get them from http://www.modelflight.com.au/kontro...controller.htm Or go hunting them down on the net. Mick
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
If your conscerned about bogging the motor you may want to reconsider your options . The 430XL motor is power hungry . The Jazz ESC, that is the best of the best speed controllers out there and its the one you want if you go that way , but its 200 bucks or so , dont quote me but it aint 99 dollars thats for sure .
the other idea would be to try a different motor . Im using the JGF500TH ( I think its around 75 bucks ) and for my buck it outperforms the 430XL . I run it on the Align 35G stock controller with 15 C TP 2100 batts on 14 tooth, throttle at 90%flat in idle up, I have tried the throttle set higher ,closer to 98% and it was scarey to the point where I thought it might explode from all the energy . This combo is extreme and I cant get it to bog even in full pitch climbout. Im getting 6.5 min flight times . Everyone who has seen my heli fly are surprised how powerful my T-REX is . Look up justgofly on the web and watch the video of Leon Lukes T-REX using the JGF500TH on 15 tooth , now thats MAD . Its my understanding that the design idea behind this motor was "no bog on 3S" |
I'ld check into the Hyperion line as well as CC to keep costs reasonable. Hyperions have a switching BEC as well to keep heat down.
JAZZ :twisted: :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
WTF@freak'n heli.crash |
#6 |
thats awsome steve 28 , 6.5 min with no bog on 15c 2100mAh,WOW what head speed are you running?
I run the 500th on a Jazz on 16c 2100mAh 4s on 11t and i still get some bog with a head speed of 3080.
#7 |
I am happy with my CC35.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail) Proud Field Representative for the following To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
The Kontronik Jazz 40-6-18 has a 5.2 Volt BEC. Measured because it's not listed in the specs.
#9 |
Wardy ,
the 500 is designed with higher pinion teeth counts , by running an 11 tooth the only thing I can think of is that your not running the motor near the right torque % . because your running a much lower pinion your headspeed isnt high enough for your pitch range and thats why you are getting bogging . Getting the headspeed higher should solve this . using the headspeed calc at readyheli using the 14 tooth I get 3152 rpm using the 11 tooth youd get 2476 rpm 2476 rpm is too low, bog city . The JGF 500TH is more efficient at the higher headspeeds try the 14 tooth and run it around 90 % and you should get similar results as me . |
#10 |
Hes running a 4s as opposed to a 3s Li Po, more voltage = more headspeed, that would explain the lower tooth count pinion.
I have a few Heli's. |
#11 |
gotcha ,
#12 |
Yep , 3080 Hs measured with my top end optical engineers tack , This is at Gov 65% with 0 pitch, I spool up at center throttle stick every flight to ensure head speed is always the same . I get 6.5 min and put back 71% and my packs are just warm . She bogs a little on full stick climb outs with max pitch at 11.5 deg and bogs a bit more when I'm really stick banging . I wonder if there is such a thing as completely bog less , do you think I would get better results with a 10t and higher throttle setting or 12t and more head room ? At present my head speed is the same when i land as it was when I take of and bat motor and esc are hardly warm so I could get way more out of it but does that mean I would end up with a head speed of 3400 trying to utilise the power? :twisted:
![]() Sorry for getting of topic
#13 |
Make sure you are using CF blades at that speed
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x **When you start to be in complete control reflexes are not a requirement.** |
