Old 03-29-2012, 02:49 PM   #21
rceccleston
Originally Posted by john604451 View Post
Those photos look no more than a pro kit bundled with the current non-DFC flybarless head and a 3GX flybarless system.
No DFC head and no torque tube.
Sent from Android using Tapatalk.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po
rceccleston is online now        Reply With Quote
Old 03-31-2012, 03:07 AM   #22
noddyflyer
the tail shafts turned up today and theres a long flat ground on one end so the gear sits on the other side of the housing to the picture in post one (its possible you have been sent the original shaft before it was modified).......mick
t250se 3blade head]t 250se fbl 250spmotor ,hitec 65hb cyclic gp780 giro mks 480mg /t250pro 250mx motor savox 257mg align g31 /ds 480mg tail/alzrc devil 450,kst 115mg cyclic/ds520 tail turnigy typhoon motor/yep 45a esc /dx8...my flying ability
noddyflyer is offline        Reply With Quote
Old 03-31-2012, 03:27 AM   #23
rceccleston
do you have any photos?
Old 03-31-2012, 07:26 AM   #24
pinguin
I think this is another version of TT kit
http://www.flying-hobby.com/shop/tre...ly-p-9624.html
pinguin is offline        Reply With Quote
Old 03-31-2012, 08:01 AM   #25
noddyflyer
that is the modified version like the one i got from oomodel (the original tail box had the gear on the other side without the spacer)...mick
Old 03-31-2012, 10:08 AM   #26
litehawkdown
30 bucks!
I think I'll stick with the belt. Replacing a TT assembly looks pricey.
litehawkdown is offline        Reply With Quote
Old 03-31-2012, 04:43 PM   #27
noddyflyer
$17 from oomodel china +post
Old 04-01-2012, 07:50 PM   #28
vk1601
Originally Posted by litehawkdown View Post
30 bucks!
Ditto
vk1601 is offline        Reply With Quote
Old 04-02-2012, 06:39 AM   #29
noddyflyer
just finnished installing the tt . tested it for vibes (smoooth no vibes ,quiet and turning the right way no mods needed) i even put an extra bearing in the boom for extra suport just got to replace the owb and setup the giro.....(no camera = no pictures)...mick
Old 04-02-2012, 09:00 AM   #30
Steve Joblin
...I even put an extra bearing in the boom for extra suport ...mick
Thanks much for the write up! What distance in from each end did you put the bearing in? the 450 only has one bearing and it is a much longer rod... do you think that two bearings are needed?
Walkera 4#3B, 4G6
Align 250SE, Gaui 200
Gootch 450PRO
Steve Joblin is online now        Reply With Quote
Old 04-02-2012, 09:17 AM   #31
noddyflyer
after installing everything there was much rattling so i put an extra bearing in just in case (third of the way in) it turned out to be the owb ,tthe tt runs really smooth ,very happy with the result i got tired of the front belt pully vibrating but the tt helps to fix the problem .....mick
Old 04-02-2012, 10:10 AM   #32
jamesb72
Infinity hobby news has pics of a 250 with DFC head and Torque Tube - no official confirmation, but looks pretty plausible this could be the 250 PRO 3GX ?
jamesb72 is offline        Reply With Quote
Old 04-02-2012, 11:26 AM   #33
noddyflyer
bought the pro frame /tarot tt and tarot fbl controler (just enough room to fit inside) and built my own might buy the new head if needed most people have built there own fbl 250...mick
Old 04-02-2012, 06:25 PM   #34
mhills51
Yes mine was one of the first. It is what you get for that crappy title lol!
mhills51 is online now        Reply With Quote
Old 04-03-2012, 08:46 AM   #35
noddyflyer
just done first hover with the tt installed and there is a difference ,had slight wag with belt but now gone tail holds solid overall i think the tt works well (only hovered it) still got loads of belt parts to use up so once the 250 pro fbl is up and running i will swap them over just need to price up a crash to see which is cheeper to fix ,belt or tt....mick
Old 04-03-2012, 01:18 PM   #36
glarepro
Belts are always going to be cheaper and more forgiving when you crash. The DFC head looks nice. The torque tube should give the bird a more locked-in feeling tail.
My 2 cents. I would love to see Align come out with this as an "out of the box" complete kit with TT and DFC included. Let the customer chose the flybarless control.
glarepro is offline        Reply With Quote
Old 04-04-2012, 03:31 PM   #37
noddyflyer
there isnt much difference in price between the parts but in the event of a boom strike the shaft would snap (ive broke a c/f tail pushrod ) i got sick of replacing the front tail belt gear the tt runs smoother, ( will the align tt be a clone of the tarot one ).....mick
Old 04-04-2012, 09:34 PM   #38
Vinno
Fingers cross they release a 250 3gx v2 with new DFC head and tt tube. Would buy it straight away and ditch the 3gx for a beastx
Ef-flite MQX - Blade 120 SR - Blade MCPX #1 - Blade MCPX #2 Brushless
Align 450 Pro V2 Spektrum Beastx FBL #1 | Align 450 Pro V2 Spektrum Beastx FBL #2 | Align 550 Pro V2 Spektrum Beastx FBL
Vinno is offline        Reply With Quote
Old 04-04-2012, 10:54 PM   #39
glarepro
+1
Old 04-14-2012, 12:34 PM   #40
noddyflyer
i am happy with the 250 tarot tt its definately quieter than belt, the tail seems locked in and i dont need to check the belt tention every 5 minutes i will see about updating my fbl pro to tt with a dfc head when available
