Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 03-17-2012, 11:16 AM   #1
Trulsen
Default Stock blades and KBDD 104mm not as good as carbon fiber blades
I have had big issues with my tail on 7HV. Tail kicking out in tic-tocs and tail wag. Ordered some kbdd 104mm extreme since ive read some good things about the kbdd blades. This didnt solve the tail issues not even the Align 700 tail hun. Tried some 107mm carbon fiber blades and all issues solved.
Edit; issues back. Maybe due to bad motor....
// Truls
- Futaba 14FG | TT Mini Titan V2 BeastX | Compass Warp 360BeastX | Logo 600 SX V-bar | Outrage Velocity 50N2 V-bar -
Trulsen is online now        Reply With Quote
Old 03-17-2012, 09:01 PM   #2
Ah Clem
Truls,
Sorry you did not like them, sir!
I am still using them on my 7HV and they work brilliantly, so something else is going on.
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 03-17-2012, 09:05 PM   #3
Blink 182
Im never listening to those kbdd sponsored pilots no more!!
// Truls
110mm-120mm seem to be preferred by those that did not like the stock or kb 104s.
The 104s i tried on a 7HV were fine, i would check the set up first, 107mm might be a bandaid.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Blink 182 is offline        Reply With Quote
Old 03-17-2012, 09:22 PM   #4
Rob43
I've not heard of any 107mm tails. Who makes those?
Incidentally, I am by no means a KBDD sponsored pilot, and I fly them on both of my birds without any shortcomings.
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 03-17-2012, 09:25 PM   #5
Raynman
KBDD tail blades work fine - maybe you got a bad set?
Team Compassmodel / Savox / HC X-series / Fusuno / rchelis.co.nz
Raynman is offline        Reply With Quote
Old 03-18-2012, 06:46 PM   #6
dankcincy
So its not that the blades suck considering plenty of people use them without issue its that they dont work on your particular set up. Maybe you should reconsider your thread title.
):> Compass 7HV, Atom 500
"Some men just want to watch the world burn"
dankcincy is online now        Reply With Quote
Old 03-18-2012, 07:59 PM   #7
r1sportbike
SIZE THE LINKS THAT ATTACH TO THE TAIL BLADE GRIPS. They are tight and cause most of these issues. Trust me.
_____________________________________________
Team Compass
Experiencce R/C
Thunderpower Batteries
r1sportbike is offline        Reply With Quote
Old 03-19-2012, 09:15 AM   #8
jt45255
+1
AMA#925546 IRCHA#3937
Team Compass USA, Pro-Star Hobbies,Mavrikk Rotor Blades, ):>
jt45255 is offline        Reply With Quote
Old 03-19-2012, 05:59 PM   #9
dankcincy
Im curious about your headspeed.
Old 03-20-2012, 06:36 AM   #10
Trulsen
Have checked my tail now sportbike. Thanks for that, but the tail were silky smooth, i have oiled it once more and still the same silky smooth feeling. Will try with one more stabilizer for the tail pushrod, since that is quite loose now with only one installed.
Here are the first test with new carbon fiber blades installed:
http://youtu.be/rf3KHK0_jkM
Dont have video with the KBDD blades installed, but the tail did not hold the tail to this video..
Not sure about headspeed, but throttlecurve at 100-90-90-90-100, Align 700mx 530kv, 13t pinion.
Will change the title if i find something wrong with another part of my helli.
Old 03-20-2012, 09:29 AM   #11
alexmit
Something is set up wrong or something is bent. If it is kicking out in tic docs and has wag, you have issues other than the tail blades.
What FBL system are you running?
Have you checked the order of the thrust bearings in the tail grips (small diameter race to the outside)?
Have you checked to make sure the tail hub is not rocking on the tail shaft?
I do however find it odd that I don't see any kicking out or wag in the video you posted with the other tail blades. My guess is that the new blades might be masking another issue.
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 03-20-2012, 10:37 AM   #12
Ah Clem
"Something is set up wrong or something is bent."
I agree.
Trulsen,
When I have a machine that is not performing well, yet I see other, similarly equipped machines performing well, I step back and look to see what is different between the way mine is set up and the way the others are set up.
Years ago (early 1990's), someone gave me a .60 sized Kyosho machine to test. I set it up and flew it, and thought it was terrible. I gave it back, declaring it to be a disaster.
I went to a fun fly a short time later, and saw someone flying one, doing what I now recognize as 3D, in a very early form. The other Kysoho flew beautifully. It was the same exact helicopter, but mine was not set up right.
I learned it after I had given it back.
The KBDD Tail Blades fly beautifully on the 7HV (and on the Odin, and on Raptor .90's, and on Trex 700E's-I have all of them flying with KBDD EE Tail Blades-I am one of many who test the KBDD Blades before they go into production).
Can you describe your set up?
KBDD-Team Pilot
Old 03-20-2012, 01:03 PM   #13
myrseth
Trulsen what bec do you have and did you ground your tail?
Klaus Myrseth Team Compass
7HV FBL fullsize VBar - 3Dplus FBL fullsize VBar - Atom 500 FBL mini VBar
JR 11X <3 - KBDD
myrseth is offline        Reply With Quote
Old 03-21-2012, 04:48 PM   #14
Trulsen
Running WR Super bec. Tail is indeed grounded. Will try the 7HV tomorrow with and without KBDDs. Will try to take a video
Old 03-22-2012, 12:21 AM   #15
myrseth
If you have ferrites laying about it might be worth a shot trying them on the super bec (lot of distortion from it), same do a manual by hand and vibe balancing of the tail. You could also try make some chineese weights on the tail, that helps too. Did that on the 3D+ because in some hard maneuvers the tail kicked, that cured the kick.
Kbdds are so light that any inbalance in the mechanics gets quite noticeable.
JR 11X <3 - KBDD
Old 03-22-2012, 04:17 AM   #16
Trulsen
Will try a ferrite ring on. Thanks Klaus! Will also put back on the stock tail hub to try if the problems are still there.
Old 03-22-2012, 07:23 AM   #17
belcom
KBDDs work as well as any more expensive carbons tails if not better. There's definitely something up with the setup. I understand it doesn't help just saying that but you can't just knock a product down publicly because it didn''t work for you right away.
Check and re-check your tail. Make 100% sure your tail thrust bearings are installed the right way. Make sure all the links are sized properly and tail slider moves smooth as silk. Check for vibrations as well. KBDDs are good tail blades but I noticed some of the pairs I had were unbalanced. Balance them and try again. Just a little piece of clear scotch tape is all it takes.
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5
RCHeliCanada.com - Compass Model - SAB Goblin - Synergy - MKS Servos - YGE - Kontronik
belcom is offline        Reply With Quote
Old 03-22-2012, 02:55 PM   #18
DominicD
The Capi - HF Support
Defamation of the KBDD team isn't a great way to get help either
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 03-22-2012, 06:33 PM   #19
chucky21022002
+1
Sent from my GT-P1000 using Tapatalk
Copter X Hybrid Beast X
Trex 500 Vbar ,Trex 600 ESP 12S Vbar
Compass 7HV Mini V
Compass 6HV Vbar
chucky21022002 is online now        Reply With Quote
Old 03-22-2012, 11:33 PM   #20
Jeff_Barrett
Sounds similar to the issues that EricW and Shawn (OICU812) were having with their tails. Sounds mechanical, and not the tail blades.
How much travel do you have setup out of curiousity?
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
