Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 03-18-2012, 08:04 PM   #1
joecass2
Default whats the max cyclic pitch with 92mm tail blades
im afraid of having a boom strike. i got 9.5 degrees on elevator and 9.0 on aileron is this safe or can i get more.
joecass2 is online now        Reply With Quote
Old 03-18-2012, 11:30 PM   #2
tr911
I don't see how you could have a boom strike to your tail rotors if you are flying spec'ed blade length. I'm running 92's on my 50 and getting +11 and -11.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 03-19-2012, 02:59 PM   #3
joecass2
i have the Kasama mixing levers. this gives me 13- and 13+ and i think i can get 10 degrees maybe more at of cyclic. with 13 degrees of pitch can i run more cyclic than 9.5? or is this getting unsafe?
Old 03-21-2012, 03:49 AM   #4
Tristin
9 degrees on cyclic, are you sure? you wont have a boom strike but could if you flying hard core 3D and running on standard blue dampers. If you flying 3D move to red dampers. I'm on red, with just over 7 degrees cyclic 92mm paddles flying 3D and no risk of a boom strike.
Tristin is offline        Reply With Quote
