Go Back   HeliFreak > R/C Helicopter Support > SAB Heli Division 630/700/770
SAB Heli Division 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 03-18-2012, 10:22 PM   #1
gww528
Default Head Speed less than 2100 RPM = new tail pulley
Is anyone using the smaller tail pulley H0049-S (26 tooth) for head speed less than 2100 RPM?
Goblin Maual v1.3 page 33
However, if you prefer flying at low/medium speed [< 2100 rpm], for best results we recommend changing the tail pulley for a smaller one to increase tail rotor rpm. In this way, you will have extremely precise tail control even at low RPM. This pulley is available in the upgrade list [H0049-S]
KBDD Team Pilot
Lynx Heli InnovationsTeam Pilot
gww528 is offline        Reply With Quote
Old 03-19-2012, 12:16 AM   #2
justindewoody
I have it, I just haven't installed it yet. I'm having tail wag issues, so I'm gonna install it tomorrow. I will let you know if it helps.
Canomod Team Pilot | Goblin 700 GREEN | Goblin 700 YELLOW | Goblin 630 | Gaui X7 | Gaui X5 | Trex 700DFC | Trex 600DFC | Trex 250DFC | DJI FlameWheel F450
justindewoody is offline        Reply With Quote
Old 03-19-2012, 12:55 AM   #3
Mystic3D
It's going to make the wag worse . See other thread
Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar
Mystic3D is offline        Reply With Quote
Old 03-19-2012, 12:57 AM   #4
TomC
Thanks Mate, I'll be interested to hear how this smaller z26 tail pulley works as well. Thanks.
Cheers,
TomC
Blade mCPX-BL,300x,450x,500x,550x(hc3sx)
Logo14, 550 blades
TT X50E, 10s, HC3-SX
TomC is online now        Reply With Quote
Old 03-19-2012, 01:15 AM   #5
TomC
Not sure why this would be the case? Could you do us a favour and give us a link to that thread. Thanks Mate.
Cheers,
TomC
Logo14, 550 blades
Old 03-19-2012, 08:50 AM   #6
gww528
Did a search & read about the tails & tail pulleys but did not see anyone using the Z26 tail pulley.
KBDD Team Pilot
Old 03-19-2012, 11:08 AM   #7
Mystic3D
Cheers,
TomC
Was referring to the cross post. If he has a wag due to binding, or ESC Gov, then increasing the speed of the tail blades will make it worse. Encountered this multiple times, have wag, flip into Idle Up, higher head speed = wag worse.
http://helifreak.com/showthread.php?t=396708
Old 03-19-2012, 01:26 PM   #8
justindewoody
What other thread?
