| X7 Discussion and support of the Gaui X7 |
Hi guys,
Given there is a range between 690 to 710mm, I'm wondering how I should make up my mind. Am I right in thinking that the larger blades will be more stable and fly "bigger"? Given my intermediate level (ff, flips, inverted ff, tic tocs), what would suit me best, and why? I think I'd like a big, floaty bird, but happy to be told I'd be better off otherwise (with accompanying explanation, I'm here to learn! I'm using the stock 520mm on my X5 and am very happy with how that flies. Thanks, Harrow. |
Blades are so subjective. Depends on what you like. I run rail 696 on all my big birds. They are crisp and responsive but don't fart as much.
Else 693s are good too. I have seen many running the new 693se blades, maybe Matt Nasca can tell us his thoughts on them. No personal experience with the radix products but I have heard good things there too. Sent from my iPhone using Tapatalk
Team Synergy/Team Scorpion |
I guess I'm wondering that once I had chosen blades by a particular manufacturer, should I be heading closer to 690 or 710mm blade size? Why go one way over the other? Or is the X7 such a big step up from my X5 that it doesn't matter so much?
I use Radix Standard (not the V2) 710mm blades: take them if you love blade farts
GAUI X7: PowerDekker 4530, JR DS8717HV, MKS HBL980, 12s, Vbar 5.3+ YGE160HV, DX18 DSMX || HJK LP1.1 HobbyManiac Teampilot |
#6 |
When I asked my lhs about the difference with 525 and 550 blades for my 550e. He replied the 525 would be better for 3d and agressive manuvers. And the 550 would be better for scale flight.
#7 |
Scale flight? Its not that big of a difference. Your rates will be a little slower, but the heli will fly a little bigger as well. larger blades push more air and have less disc load, so the heli will feel a bit lighter as well. But not as nimble. You will also not need as much headspeed with larger blades due to less disc loading.
In the end, its very hard to explain the differances with out actually flying larger blades against shorter ones on the same bird yourself. If you are not into medium to hard 3D you may like the longer 710-713's.
AnythingHeli.com OWNER/ TEAM PILOT GAUI X5 / X7 * GOBLIN 500/630/770 * TREX 500DFC / 450DFC@6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Hmm, okay, so I'm gradually getting into medium 3D, I guess I don't want anything larger than 700mm.
#9 |
Remember, its not that the 700+ do not do 3D well, just different (almost more graceful if you will, better for big air stuff, etc..). Most 3D guys do prefer 690ish over 700+ though.
#10 |
My opinion would be to go 693 size. I've been running the EDGE 693 SE baldes and they are real nice! They feel to me like a cross between the FBL and FB blades; smooth but crisp and stiff.
710s can be flown in 3D but you just don't get the quick rolls and flips like 693s give you. The longer blades are real good for sport flying or big fast flying. But they do take a toll on the packs and motor because there's more air resistance with the bigger disk. The 690 size is a good all around performer. My .02
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 (R.I.P.) - All on VBar 5.3 Pro GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster |
#11 |
Thanks Matt,
But I'm just wondering for learning piro flips (eventually), etc., would I better of with the more stability of a slightly larger blade? |
#12 | |
Since blades are one of those things that's consumable, buy a set of both and try them out for yourself and see what feel you like best!
#13 | |
That being said, I like 693's myself. Although the 800mm's I have on my 700E are a blast to do some HUGE air stuff as well as smooth consistent piroflips.
#14 |
Yeah, good point, I'm gonna crash eventually, so I might as well buy two pairs up front and test. And if I don't crash for a while, well the cost of the 2nd pair is a lot less than the crash I didn't have, so I'd have nothing to complain about.
#15 |
Heard nothing but good things about the Rail blades.
#16 |
I'll be trying them out next, along with SAB 690x63, 690x64, and 700x63. SAB are just crazy fast blades, extremely lightweight and stiff.
E7 | E5S | E5 Team Synergy | Gens Ace | Scorpion Motors | Progressive RC | Anything Heli |
#17 |
I have the Rail 696 blades on mine, crisp, responsive. Very good feeling. I have tried Edge(not the SE) 693 on my Synergy when the rails weren't available, I ultimately liked the Rails better. But again, blades are kind of subjective. A good blade is a must on a bird this size, don't buy for price alone. But if your budget allows, try a couple different before you settle on one. Worse case you will have a crash set.
#18 |
Has anyone tried the rotor tech 690 flybarless blades? I've, so far, loved all the rotor tech blades I've ever flown . I've only had a few blades to compare them to such as sab align and Curtis Youngblood. The rotortech blades have been more efficient and powerful allowing longer flight times with crisper response.
#19 |
Will Edge 713 FBL blades work with Edge 105 tails without hitting each other on the X7?
Velosity 50 Nitro, 5.3 Fullsize vbar, Rails X5 FES 5.3 Fullsize vbar, Edge Futaba T8FG Super Team Helidirect |
#20 |
