Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 03-19-2012, 02:55 PM   #1
Danny_Swe
Default Hyperion 4035-560
I just can't find clear answers in this. So may I please ask if you know good standard settings for this motor.
I'm not so experienced so I can tell when the motor is running smooth or so. Just use some standard setting and then in the future maybe learn this.
But for now. What timing and pwm do you recommend? For running this motor cold but efficient on a YGE 120HV controller.
(the motor is the same as Scorpion HKII)
TDR, 550E, 450Q | VBar, YGE, DX8 | Olympus OM-D
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
Old 03-20-2012, 04:23 AM   #2
Georges van Gansen
Owner Scorpion Motors
8Khz and 5 degree,
Georges van Gansen is offline        Reply With Quote
Old 03-20-2012, 05:38 AM   #3
Georges van Gansen
Sorry! correction, for YGE, try 18 degree.
Old 03-20-2012, 06:44 AM   #4
Danny_Swe
ok, I actually have 8 kHz and 5 degree now, but I will change to 18 degree then! (have not tried it yet).
Thanks!
Old 05-01-2012, 06:02 PM   #5
Danny_Swe
just to add something interesting...
found a formula:
pwm = Kv x pole count x nominal volts used / 20 = 560 x 12 x 44 / 20 = 14,8k
so I got 14 kHz and set the ESC on that.
What a difference! More power now, much more torque, but the motor runs alot warmer also (but it goes smooth and nice in both cases). Well well. I guess it's a trade off. Coldness or Power. For now I think I prefer the latter option
Old 05-01-2012, 11:22 PM   #6
powercroco
forget this formula!
there are much more influences than only nspec, voltage and number of poles!!!
it doesn't really works.
powercroco is offline        Reply With Quote
Old 05-02-2012, 03:18 AM   #7
Danny_Swe
ok! thanks for bringing light on this matter. I guess it's a trial and error process of finding the best value for your setup. I hope I found mine now think I will try it like this for a while.
Old 05-03-2012, 03:28 PM   #8
NRPY
What else do you recommend to get settings "in the ballpark"?
NRPY is offline        Reply With Quote
Old 05-04-2012, 01:17 AM   #9
MrMel
V-BAR Guru
Check temps on both ESC and motor, I've found it depends on what ESC, and what motor.
Scorpion ESC likes 5 degree, Hobbywing must be set at 15
Likewise Xera needs higher than Scorpion motors and so on.
MrMel is online now        Reply With Quote
Old 06-29-2012, 05:32 AM   #10
Danny_Swe
alright, here's the inside. I thought it was supposed to be other bearings than standard there. But whatever, it's good anyway. The magnets are really strong when you pull it out.
Old 06-29-2012, 09:32 AM   #11
alexmit
I have seen you post about that formula being no good and most of us know you are an expert on this subject. Is there any sort of formula one could use to determine optimum PWM and timing?
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 06-30-2012, 01:05 AM   #12
Stolla
there is no formula, but you can follow manufacturers recommendation and then check motor temps performance etc, if it doesn't work well tweak from there.
