| Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters |
Hello everyone.
Just had some questions about swash adjustment /servo travel adjustment. How far can I allow my swash to roll before it could cause trouble? For example.. I want my mini t to flip and roll as fast as possible, but not to far that it causes a boom strike or overbinds the head. What Is the best way to determine this? Any help will be appreciated! Btw its a basically stock mini t head wise Sent from my MB870 using Tapatalk
PRÔTOS....a better way to fly To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
You could replace the white paddles on the flybar with the green ones from ThunderTiger. They weigh less and allow quicker cyclic response.
If your heli is working and flying correctly this can be an easy way to speed up the cyclic response before messing with anything else. -John
Swift NX 550 (x2) | Swift 16 550 | Mini-Titan E325 SE | Mini-Titan E325 Pro (x2) | Blade 400 | Quark SRB (x2) | Blade mSR | Blade mCX |
Thanks. I have the green paddles already. Im just looking for a way to know the limits of my swash. I can give it alot more throw
keep increasing travel until it binds then back it of a bit. It's probably not the correct way to do it but that's what I do and it seems to work...
...or go FBL |
the only thing I'm concerned about is hitting the tail boom with the main blades. I have done that before with devastating consequences. don't want it to happen again
#6 |
I am not sure but isn't this more related to how much are main blades able to flex in the flight? If you have some hard to flex blades (Edge) then they should never hit the boom (maybe in crash but that's not what we are looking for).
Titan e325 SE flybarred | Titan X50 flybarred torque tube Futaba 10C in mode 3 |
