Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 04-10-2012, 09:03 PM   #21
meatwad99si
Automotive technician - but really a rocket scientist
Its not lazy gyro wag its crazy freakout wag...
meatwad99si is offline        Reply With Quote
Old 04-10-2012, 09:07 PM   #22
DoctorJ
Turn down your cyclic gain if it is not at 12 o'clock.
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - CC 50
Blade 130x - HP08 - CC ( many others )
DoctorJ is offline        Reply With Quote
Old 04-10-2012, 09:54 PM   #23
tamupino
I tried adjusting cyclic gain per your suggestion with no luck . Goes into crazy tail shudder mode with sudden control inputs.
tamupino is offline        Reply With Quote
Old 04-10-2012, 10:37 PM   #24
DoctorJ
Can you put your gyro into rate mode by reducing gyro gain almost all the way and see what happens. The will help diagnose
Old 04-14-2012, 02:38 PM   #25
azezeil
Well guys...I figured it out. I did some trouble shooting with the tail and when they assembled them at the factory they must have not torqued the screws enough on the plastic mounts. Whats happening is under heavy load the servo mount is pushing up and twisting the servo rod. I noticed this first because I did some extreme pitch pumps for about 10 seconds then brought her down and gave her a once over. Noticed the rod was bent, straightened it back out, and tried again. Same thing, so I torqued the screws to the point where I was afraid of stripping the plastic and it fixed it.
I have the aluminum mounts on their way so I'll be swapping them in along with my H5020G servo, but I'm glad that it was something so simple. Just annoyed it took me this long to finally get some free time to really dig into it.
azezeil is offline        Reply With Quote
Old 04-14-2012, 10:26 PM   #26
meatwad99si
Hmm thats interesting ill have to make sure, i tighten mine up.
Old 04-16-2012, 02:41 AM   #27
Talesin
Interesting. Mine were flexing more just before my (I /think/ unrelated) crash, and got the crazy tail-wag two or three times (very visible on the video). Ordered the aluminum mounts since the tail had to come off anyway.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X
Spektrum DX8, DX6i
Talesin is offline        Reply With Quote
Old 04-16-2012, 03:22 AM   #28
meatwad99si
Do the aluminum mounts hold tighter? Im prob gonna get some when i get my mks servos.
Old 04-16-2012, 04:02 AM   #29
Talesin
Yeah. There's no flex like the plastic ones, and even pressing *hard* with a thumb, with the screws only lightly tightened they don't seem to move at all; much less tightening them down solid.
Spektrum DX8, DX6i
Old 04-16-2012, 03:50 PM   #30
meatwad99si
yeah it seems like once you move the servo mounts or pushrod guides from there stock locations they never hold the same...
Old 09-07-2012, 06:09 PM   #31
krante
Default Blade 450X Tail vibration
I there, I get this very issue when I stick rudder all the way to the left or right for multiple pirouettes. The tail vibrates violently that I had to land quickly. I don't quite follow your solution described above, any chance of a picture please?
First time I had this issue, I thought it was a bad tail servo so swapped it out to MKS DS95i but it did not fix the problem.
Any help will be much appreciated.
DK
krante is offline        Reply With Quote
Old 09-08-2012, 04:37 PM   #32
Coco66
DK
From what I understand, azezeil was tightening the screws which fix the two plastic tail servo mounts to the boom.
2 X Blade mCP X v2 ♦ night fly Blade mQX ♦ LadyMQX hybrid ♦ Blade 450X w/telemetry and Loc8tor ♦ Blade Nano CP X ♦ Compass Warp 360 w/AR7200BX, (2nd) Koby 40, DS92A+, DS95i, telemetry and Loc8tor ♦ Spektrum DX8/DX6i
Coco66 is offline        Reply With Quote
Old 09-09-2012, 04:45 PM   #33
AZHELIMEDIC
Mine did the same exact thing when I put on the kbdd 62mm tail blades. As soon as I put stockers back on problem was solved.
AZHELIMEDIC is offline        Reply With Quote
Tags
bad, blade 450x, oscillation, tail vibration, weird
